HL Pershing Gun Length, Correct Scale?
Does anyone here know if the HL Pershing's gun length is correctly proportioned for scale?
I have read some reports that it is not and it needs to be "stretched" about 30 millimeters.
Any info would be appreciated.
RE: HL Pershing Gun Length, Correct Scale?
that's correct...it's too short and width is also out...it's about a 105mm as it comes. Same with most HL guns because they are set up for the Airsoft BB shooting.
Thanks, that's what I thought.
At least for the Tiger I, they offer a longer barrel as an accessory, I think for the Pershing, a person would have to come up with their own solution.
In my case, the goal with a future Pershing would be an SLU conversion, if it was no longer able to shoot airsoft, I could live with that, I already have some good airsoft "shooters".
Get the Tamiya gun and mantlet assembly. it fits in the HL Pershing turret just fine. all it needs is a little trimming and it works great.
I got the barrel and mantlet sprue from the AAF.
Take a short-cut. With a few minor mods, you can have a pretty nice M-45. Cut the gun and you have an already installed 105mm.
MN
ORIGINAL: pattoncommander
Dan
ORIGINAL: fynsdad
the trouble with extending the barrel is that you can get a bit carried away
Frank
Frank
What sort of Tracks are those ?
The tracks on the model are T-66's, made by kenny kong, I think?? I managed to get them cheap secondhand. Although I think the "original" Super-P's had T-81's. but they're close enough for me
Frank
Frank
Thanks for all the info
Yeah, but only if you can think of the right phrase to use in it I din't have any luck with it
ORIGINAL: swathdiver
The "search" feature is your friend.
Try it again but look at posts from 2006 first, either way if you add 32-33mm to the gun tube you'll be fine.
You could go real long and make a Super out of it. there where only 2 but who cares. the HL Pershing works well for that conversion. May still do it to mine one of these days now that I have a Tamiya Pershing. My HL has all Tamiya hardware inside including the gun and recoil. it also uses a servo elevation that works unbeleivably well.
What is the size for the T26E3 type.
Cheers
John
__________________________________________________ __________________
HL Pershing x2, Tiger l, Jagd/Panther G, Pzrlll x2 ,Pzr lV, Stug. lll Tam Sherman E8 Mat King Tiger
What's better playing or building the tanks
