Good webiste for LEDS
Old 05-30-2011 | 01:03 PM
yellowshaker's Avatar
Default Good webiste for LEDS
Guys, I am working on the KT and wanted to make the lighting functional.I found this website aq while back and thought I'd share with you all. Using a pico switch, I am able to hook up the 1mm LED with full power from the 7.2v battery pack. These work on 9v, so you need no resistors inline. I just finished installing it in the kT and works prerfectly.
http://www.modeltrainsoftware.com/bl-214f.html
Old 05-30-2011 | 01:48 PM
Default RE: Good webiste for LEDS
Thanks for sharing
Old 05-30-2011 | 02:02 PM
That's a nice way to disguise more than one IR emitter.....he he.  Have to keep an eye out for that.</p>
Old 05-30-2011 | 03:23 PM
fsciorelli's Avatar
Cool deal Yellowshaker,
LED's are wired and already have the resistor in them. You can see it as the bulge under the shrink tube in the left hand lead
Good LED installation tips on the link on the same page
Old 05-30-2011 | 03:42 PM
Yep, they are all ready to go. You can use these in an HL tank as well, and not worry about blowing them. They work nice.
Old 05-30-2011 | 03:48 PM
fsciorelli's Avatar
Yellowshaker,
I just noticed you have a Tauchpanzer with Elmod. I'm not so much interested in the elmod, but whether or not you have a recoil mechanism installed. I've been having a dickens of time trying to get an Asiatam unit installed in the Pz III H"Tauchpanzer" I have. I'm having problems with gun alignment and I don't know if there are some slight differences between the Pz IIIH and the Pz IIIL.
Old 05-30-2011 | 03:56 PM
Yes Frank, i have an Asaitam unit in mine. It was actually designed for a Tiger 1 so making it fit in the PIII hull was a challenge. The brackets are different, so I ended up making my own. I think Phil could tell you if there is any differences in the units for the PIII though. What problem arfe you having exactly with the gun alignment? Do you have any pictures?
Old 05-30-2011 | 04:30 PM
fsciorelli's Avatar
Yellowshaker,
Here's the link to a previous thread where I tried to get the gun alignment worked out.
http://www.rcuniverse.com/forum/m_10...m.htm#10102909
Scroll down a bit to the pictures I posted. The recoil is working, but the mantlet is spaced out too far and shifted down relative to the turret. Since then I modded the mounting holes for thetrunion mountsto close the gap up and shift it up, but now the gun gets locked up in themetal bushing. I'm getting a bit frustrated and thinking about trying to mod a HL recoil unit per the Bubbajoe method on RCCommand website
