 Muzzle flash HELP needed. >
Old 06-02-2011 | 01:18 PM
Default Muzzle flash HELP needed.
After installing a dbc/dbu into my Stug III everything works properly except for the muzzle flash in
my Heng Long tank. I have to have it working by this Sunday for an upcoming NEAD battleday.
Upon opening the tank I found that the red wire from the LED lamp in the muzzle appears to
have broken off the small terminal board located next to the recoil assembly.This terminal board
only has eight pads or connection points on it, and the first two pads are wired to the recoil
assembly switch.Also to one of those two wires is connected the low side (Black wire) that comes from the muzzle led. Can anyone direct me to where the red (or positive ) side of the muzzle led
should go on the terminal board.I`m tempted to connect it to B+ but that might burn out the led.
Charlie
Old 06-02-2011 | 03:15 PM
Default RE: Muzzle flash HELP needed.
I'll have to look at my DBC set up to see. It is in a T-034/85 but the wiring should be the same as everything is converted to HL RX 18.
