Tamiya M4 track problems
Old 08-30-2011 | 04:51 PM
Default Tamiya M4 track problems
Hi.
I have an old Tamiay M4 DMD version which I overhauled w/ new gearboxes and some newer parts ans schmok shaft supporter.
It runs fine on paved road but when it went on the grass or gravel, right side track came off.
tension and wheels, sprokets are look ok..
How I can fix this?
Old 08-30-2011 | 07:01 PM
Default RE: Tamiya M4 track problems
Check your idlers. The Tam setup has the plastic idlers turning on metal shafts sans bushings or bearings. With time they wear and get out of alignment. Fix is either a new set from Tamiya or some aftermarket parts.
Sev
Old 08-30-2011 | 11:18 PM
http://www.stellamodels.net/catalog/...oducts_id=5629
