HL Pershing question??
Old 12-07-2011 | 06:55 PM
Captain Action's Avatar
Default HL Pershing question??
Good day
I have a HL Purshing and I would like to know how to take off the foward most road wheel from the suspension arm.
Has any one taken one apart,?
It has a lot of slop in it and is binding the track so I wish to take it apart and shim it up some.
thanks
Old 12-07-2011 | 07:27 PM
DirtyBird69's Avatar
Default RE: HL Pershing question??
It should split in half(use a very small screwdriver or an exacto-knife)......then you should see a screw holding the inner half of the wheel to the suspension arm..
http://www.gorcgo.com/index.php?rout...ter_name=m41a3(if the wheel is bad you can buy extras here)....hope this helps
