DAK Hellcat
Old 05-20-2012 | 08:15 PM
edoubleaz's Avatar
Default DAK Hellcat
Surprise attendee:
Untitled by edoubleaz, on Flickr
Old 05-21-2012 | 04:13 AM
karel47's Avatar
Default RE: DAK Hellcat
nice hellcat build it yourself ???
Old 05-21-2012 | 09:18 AM
edoubleaz's Avatar
One of our members used a HL Pershing to do the conversion. Sherman electronics and Kenny kong metal PZ IV track. Built what you see in 10 days....
Old 06-11-2012 | 10:31 AM
damn ****ing good,
did he made pictures or anything else during the build?
damn i want one too ^^
Old 06-11-2012 | 12:12 PM
is it just my eyes, or do the drive sprockets have a cosmetic cover with the proper tooth profile? I'd like to see a closer photo...
Old 06-12-2012 | 07:33 AM
karel47's Avatar
yes me too can we have closer foto's please
Old 06-12-2012 | 07:01 PM
click on photo it takes you to flickr and then you can make it bigger.
Jimmy
Old 03-27-2014 | 09:02 AM
edoubleaz's Avatar
The hellcat suffered a few mechanical failings but has been rebuilt and managed to turn the tide a bit at the last DAK battle. New HL gearboxes, a stiffened lower hull, and internal wiring mods now make it a lethal little tank destroyer.
<a href="https://www.flickr.com/photos/68007800@N06/13449894135" title="Untitled by Ethan Dunsford, on Flickr"><img src="https://farm8.staticflickr.com/7278/13449894135_394ed912ee.jpg" width="500" height="267" alt="Untitled"></a>
<a href="https://www.flickr.com/photos/68007800@N06/13449896285" title="Untitled by Ethan Dunsford, on Flickr"><img src="https://farm3.staticflickr.com/2935/13449896285_1d0d3b80f7.jpg" width="500" height="199" alt="Untitled"></a>
<a href="https://www.flickr.com/photos/68007800@N06/13450270384" title="Untitled by Ethan Dunsford, on Flickr"><img src="https://farm8.staticflickr.com/7429/13450270384_1fb6766527.jpg" width="500" height="426" alt="Untitled"></a>
Old 02-12-2018 | 02:19 PM
edoubleaz's Avatar
Really need to update builds more often! Rebuilt the elevation and traverse to make this guy really slick. Rebuilt the front end for more structure and cosmetic durability. I confess to adding a new emitter (San Diego) style to make it a true tank destroyer. More to follow!
Old 02-12-2018 | 03:42 PM
Nice 'cat - do you have any pictures of the recoil and elevation set up? I need to get mine working, but as its likely going to have an MF-02 in it, it will have to be a servo driven by a channel mix on the radio.
(Unless anyone knows of a gizmo that will take the Tamiya recoil starting signal and trigger a servo cycle..?)
Old 02-12-2018 | 04:06 PM
edoubleaz's Avatar
Old Sherman guts.... No recoil YET!!!!
Old 02-14-2018 | 08:43 AM
Green Amphibian's Avatar
RCtankhobby.com makes a recoil board that works well for servo recoil with Tamyia boards. See my Hellcat build pictures.
Herman
Old 02-14-2018 | 10:28 AM
edoubleaz's Avatar
I have the board (thanks Nick!) and I have made it work with my M36 project using a Pershing DMD/MFU board. My real question to you (and Tankhobby aka Nick) is can it be hacked to work with an old Tamiya Sherman DMD/MFU that has no recoil port? I typically use cheaper radios so complex mixing is out. I want to add recoil to my Chaffee/Hellcat/Shermans that run the old guts..... Ideas?
Old 02-16-2018 | 11:45 AM
Try running power to the board and use the signal from the flash to trigger the recoil. Not sure if that will work or not. I hope someone with more electronics knowledge than me (I have none really) can answer that or give another suggestion.
Herman
Old 02-16-2018 | 12:00 PM
Possibly using the positive on IR led might work as a trigger too
Old 02-16-2018 | 01:12 PM
edoubleaz's Avatar
I have always considered the flash as I basically don't install them... (can't see them in broad Arizona daylight!) Will the board handle the higher voltage of the flash unit?
Old 02-16-2018 | 03:58 PM
Tankhobby's Avatar
The flash voltage is too high! It might work the first few times but eventually could blow the board. Triggering off the IR LED will work. All you need is a positive pulse to trigger it (but not too high a voltage like the flash unit).
Old 02-16-2018 | 04:02 PM
RichJohnson's Avatar
The right value resistor off the flash pulse would be the solution for that scenario. Though, im a bit rough with ohms law on calculating the voltage drop taking into account the current value.
IR positive lead soudns like a viable plan.
Who will be the first to make the howitzer recoil?
Old 02-16-2018 | 06:32 PM
edoubleaz's Avatar
Tank hobby (nick) I need more boards!!!
Rich, I already made a howitzer recoil with Super Sherman DMD/MFU!
Old 02-12-2026 | 12:05 PM
edoubleaz's Avatar
I have listened to the unofficial poll suggested for my next build last week and have redoubled my efforts to get a new M18 Hellcat running on our field. Until then, the old one has seen a fair amount of use and abuse so it is time do the work to get it running again in advance of my 3D printing effort. Two is always better than one!
The old Hellcat has always been a cosmetic conversion with some external detailing so allow mw some artistic license in the rework. This one only has to look good from 10 feet away! In the last few years I have made the effort to print a new one but those efforts have not worked out very well except for a few parts here and there. I made the decision to remove the basic dust jacket the original builder included to simplify his project and make the actual rotor shield and mantlet. These parts came from a solid Hellcat model that I enlarged off thingiverse from a gaming model. Today's effort is to fix that and add some components from the Tamiya parts bin and Andys 76mm Easy Eight. I also decided to flesh out the loaders position with spare M36 parts and card stock. I know its supposed to have 9 rounds but forgive me for now!
Old 02-12-2026 | 03:09 PM
Well now, here's a blast from the past
Old 02-13-2026 | 11:59 AM
edoubleaz's Avatar
Work done on incorporating the M1A1 76m from the Andy's HHQ Korean Easy 8. I know it is painful to watch me going away detail to make it workable but don't worry, I have another!
During this evolution I decided to use the metal barrel from the AHHQ because..... it looks good......
Emitter will now go in the mantlet gun sight. Looks good so far!
The following 2 users liked this post by edoubleaz:
Ex_Pat_Tanker (02-13-2026), tankme (02-13-2026)
Old 02-16-2026 | 06:47 AM
edoubleaz's Avatar
New elevation servo added to solve a "chatter" problem with the elevation and I had a few minutes to field test. Real smooth and the Hellkitty is back in business.....
Now to the new emitter and to find a battle system.
tankme (02-16-2026)
Old 02-16-2026 | 10:58 AM
Looks great. I have a similar chatter problem with my M1128 MGS elevation. I guess I'll have to look at replacing the servo also.
Old 02-20-2026 | 08:23 AM
Very cool!
BTW: www.desertarmor.com mentioned in your signature -- possible SSL certificate issue?
bowlman (02-20-2026)
