WSN T-34 front hatch
Old 06-09-2012, 01:31 AM
Rock1997
Default WSN T-34 front hatch
Hi guys,
I just got a WSN T-34 and found the front hatch cannot open....actually there are no hinges. i opened up the upper hull and found that part is just a shape....no movable part... this is not what i saw from others. ppl can open their front hatch.
I got correct product or something changed??
Thank you
P.S. I will upload a picture tonight.
Old 06-09-2012, 02:56 AM
Wozwasnt
Wozwasnt's Avatar
Default RE: WSN T-34 front hatch
Is it the IR version?
The old WSN had a working hatch but I don't think the IR ones do.
Old 06-09-2012, 03:52 AM
Rock1997
Yes. the one i got is IR version. I didnt know they have two versions. Anyway, Is that possible tomodifyit to be a moveable hatch? Also, i wanna replace existing electronics to HL and any recommendation?
Thank you.
Old 06-09-2012, 05:16 AM
Airbrushler
Airbrushler's Avatar
you will have to cut it out for it to open mine is the same
Old 06-09-2012, 08:59 AM
Panther G
The early versions had an opening hatch. All mine did [3]. I dont know exactly when they stopped doing it. Silly if you ask me.
Old 06-10-2012, 12:58 AM
Panther F
Panther F's Avatar
Aaahh, it doesn't need to open. Nice if it does (I installed my power-up switch there) but not a deal breaker if it doesn't. DT makes an operational loaders hatch (at least he used to) that can be installed in the turret for your switch if using an Apple for a battle system. Otherwise the power switch can go in the cupola.
HTH
~ Jeff
Old 06-10-2012, 07:30 AM
Rock1997
Thx guys. I think it's better it cut it out and move the main switch to the position just behind the front hatch. Is any1 using the ThinkTank tank module Eco (www.el-mod.de)? I thought it is much better than hl electronics as u just need this board and connect to ur receiver. If I am using this board with a futaba 4 channel radio what the performance will be? Is this a good deal for electronics upgrade? I don't need fancy Ir system and I am pretty  much prefer the moving system and turret turning.
 I will be modifying this tank little bit more in following couple of weeks/months.
Old 06-10-2012, 09:10 AM
Airbrushler
i'm still working on mine i opened the two top hatches one for the SLU the other for a commander but don't have a good one yet...lol i still have to hinge it, i still have to open the back that's where my switch is and not sure if i need to open the front one
ID:	1770732   Click image for larger version
ID:	1770733   Click image for larger version
ID:	1770734   Click image for larger version
Old 06-10-2012, 11:47 AM
Rock1997
I know a place where they sell hinges. Check it out.
http://www.phoenixmodeldevelopments.com/acatalog/The_Phoenix_Miniature_Hinge_Range.html
hope this will help.
