Reload this Page >
3D Printing Tank Treads, etc
Old 09-06-2013, 03:44 AM
Oracus
Oracus's Avatar
Which printer do you have? Whats the issue?
Old 09-06-2013, 05:23 AM
Oracus
Oracus's Avatar
Originally Posted by Pah co chu puk
The trick is getting accurate measurements to make the CAD file with. I would need a real track link to measure, or a copy of the origonal factory specs. With one of those to work with I could draw the CAD file needed to 3D print track links.
Anybody out there have a copy of E-100 track section factory specs?
Or any other desired tracks?
From what I have read the E100/Maus tracks are a larger version(1100mm wide) of the henschel turret King Tiger.
Old 09-06-2013, 06:22 AM
mustclime
mustclime's Avatar
the e100 tracks are kinda close to the early kt tracks but they are centered. That is the guide teeth/ holes for the drive sprockets are centered. The spring for the suspension were out side the hull so the drive wheels moved away from the hull to make room.
Old 09-07-2013, 07:26 AM
Cruiser133
Cruiser133's Avatar
I am in the process of buying the Juckenburg E-100 kit if anybody needs a section of track. I will send it to them to use for whatever purposes they might need it to get the project going....
Old 09-12-2013, 09:29 AM
DeadTom
DeadTom's Avatar
Originally Posted by Oracus
Deadtom,
Well Makibox's are starting to ship! Yea! I am starting to build my 3d scanner and acetone vapor chamber for finishing parts.
Anyone who would like to design parts I will gladly accept .stl files, gcode or cad drawings that i will import myself. Eventually I would like to produce parts on a small scale. I do this to further our great R/C hobbies!
Yes I saw Jon's update....again.
I am usually pretty upbeat about things of this nature but it is coming up on the 2 year mark since I ordered it. I knew it was not going to be a slam dunk as we all were led to believe. I have thought about pulling my money but at this point I guess it will ride.
Someday my printer will come.....
Old 09-12-2013, 09:49 AM
  #31
Imex-Erik
Imex-Erik's Avatar
Deadtom,
I myself have a acetone chamber, aka a steamer from wallyworld. I bought it for about $20 and it has a nice cast iron base and a quick release plug for the temperature knob. I simply pour in a cap or two full of acetone, set my part in the basket (which sets about a half inch or so above the bottom so your parts arent sitting in it) put on the lid and set to about 200F for about 30 seconds. Voila! I'll try to make a video when I can of it, I need to make a few things this weekend anyways. It is very simple and the best cheap way I've found so far.
Old 09-14-2013, 06:52 PM
  #32
THE_BREED
Seems to me if you had a big enough printer you could cad model and print the parts for an entire tank in abs. now wouldnt that change scratch building.
Old 09-15-2013, 10:03 AM
  #33
Rex Ross
Youse kids today are lucky ....... Ya got CAD drawings, 3D printers, CNC machines, and other nifty goodies to play with.
This is the only hi-tech gizmo in my stash...........
Old 09-15-2013, 12:30 PM
  #34
Oracus
Oracus's Avatar
True! But you could also break it into sections and assemble them afterwards.
Old 09-17-2013, 11:39 AM
  #35
MK1 Nut
Hi All,
I've had a little success with printing track for my First World War Tank project. I have made some basic ones to test the link length and cog mesh, also a more scale-ish one to get made by a local firm.
Don't actually have a printer myself, I'm using my brothers Makerbot 3D printer. Drives you mental, but well worth it in the long run. Takes a while to get used to all the little foibles of 3D printing, but I've made parts I could never have done without it.
Helen x
Name:	Me and Tank.jpg
ID:	1921734   Click image for larger version
ID:	1921735   Click image for larger version
ID:	1921736   Click image for larger version
ID:	1921737   Click image for larger version
ID:	1921738   Click image for larger version
ID:	1921739   Click image for larger version
ID:	1921740   Click image for larger version
Old 09-17-2013, 12:40 PM
  #36
Pah co chu puk
Pah co chu puk's Avatar
VERY Cool! Great project... any more pictures of the tank?
