newbie
Old 10-30-2012 | 06:40 PM
Default newbie
Hello, new guy here. I started out a couple of months ago with the Heng Long Tiger 1. Cool tank, but the motor on the right side seems to lock up and makes a loud clicking noise. Has anyone else had a problem with the motor locking up?
Old 10-30-2012 | 06:58 PM
Green Amphibian's Avatar
Default RE: newbie
I don't know much about HL tanks, but check your gearboxes for smooth operation and stripped gears. Have you used any lubrication on them? Were they broken in before use?
Herman
Old 10-30-2012 | 07:59 PM
FreakyDude's Avatar
Default RE: newbie
cav scout as green amphibian has said your gears are more than likely the cause of your issues. Take a close look at the teeth on the gears and see if any have been worn off, Usually with the Tiger it is the first gear after the motor/pinion gear. At least that is my experience with quite a few Tigers I have seen.<div>Let me know which gear it is and I'll see if I have it in my spares.</div><div>
<div>
</div></div>
Old 10-31-2012 | 06:07 PM
Default RE: newbie
Thanks for the info guys. The gears were the first thing I thought it might be. I checked all the gears and they all look good. It doesn't do it all the time. It seems to start making the noise after about 10 mins of running it. Then it will run fine then start making the noise.</p>
Old 10-31-2012 | 06:09 PM
Buckeye36's Avatar
Default RE: newbie
Metal or plastic gears?
Old 10-31-2012 | 06:30 PM
Default RE: newbie
Their the plastic gears. I was looking at the brass ones or the metal ones. Not sure if I really need the 3:1 brass ones.</p>
Old 10-31-2012 | 06:39 PM
Buckeye36's Avatar
Default RE: newbie
The plastic gears have a slip clutch gear to prevent stripping, it clicks when it slips.
That is probably what's happening.
Old 10-31-2012 | 06:45 PM
Default RE: newbie
That sounds like what it might be. Thanks again for the help.
Old 10-31-2012 | 06:59 PM
Buckeye36's Avatar
Default RE: newbie
No problem.
