Hooben 1/16 T-55A with RealRecoil Mod
We've just upgrade gun barrel recoil on Hooben T-55A
[youtube]http://www.youtube.com/watch?v=UjLurAYVYao&feature=em-uploademail[/youtube]
Regards,
Clark
RE: Hooben 1/16 T-55A with RealRecoil Mod
Looks realistic!!!
Very nice Clark! I'm very tempted to used the Tamiya kv electronics currently in mine for something else and drop on of your boards in.
AB, CANADA
Every Clark board is capable of this real recoil. It is quite nice. All you do is mode the mechanism to accept a servo and then plug it into the Clark Board.
ORIGINAL: texchap
Outstanding. I seem to have consistent problems with the Hooben system. Are there plans for this upgrade? Thank you.
Hi,Richard,
As you can see at the begging of video, this modification is very simple, remove gears and motor from original recoil unit, fix a 9g servo at the end of recoil unit, use 3mm metal wire as linkage between servo arm and TF4 part, and then plug servo to RealRecoil port. you don't worry the swing direction of servo because it can be set by tank personalization function on TK board.
Here is another video with more clear view of modification.
[youtube]http://www.youtube.com/watch?v=td5vOBV2kfM&feature=em-uploademail[/youtube]
Here is a example of modification on HL recoil unit for your refence
Here we use servo recoil on 1/25 Panther
[youtube]http://www.youtube.com/watch?v=HtppZMD4TJM[/youtube]
Regards,
Clark
ORIGINAL: mordock999
Fantastic! The only thing missing is the Smoke!!
[youtube]http://www.youtube.com/watch?v=ICc6ObVWubc&feature=em-uploademail[/youtube]
Regards,
Clark
Clark, so good to see you posting here. We need more capable & informed manufacturers like yourself involved on the forums.
ORIGINAL: herrmill
Thanks Herrmill, but the best and quick way to get technical support is stil to send us email becasue I may lost some post on the forums.
Regards,
Clark
ORIGINAL: Warlord_Link
Hi Clark,
I would like to do real recoil too and thank you for your guide.
Jade
Hi Clark,
Jade
Regards,
Clark
