TK20 Controller works but no Airsoft function Need HELP.
NY
I bought the TK20 Controller unit 2 weeks ago got everything to work but airsoft bb unit, when i move my left stick down Main Gun fires but no airsoft.The way my radio is setup is left stick controls Main Gun sound, Turret movement, Elevation movement, Lights on/off, Machine Gun sound, Engine Startup/shut down.
The right stick controls all drive movements, I just can't figure out the airsoft any help or advice would be I would be happy to have from anybody out there.Oh yah radio is a Flysky model FS-CT6B 6 Channel 2.4 ghz radio.
I would assume the reason is most likely due to the fact the boards are defaulted to Tamiya recoil mode, & not Heng Long Airsoft mode.
Unfortunately for airsoft users you will still need a HL IR receiver apple (or other receiver) to hook up to the board & reprogram the correct settings.
You might want to also look over the TK20 Series page on Clark's website to check & see other possible modifications you might want/have to do for Heng Long Airsoft.
The below chart is directly from the Clark Model website TK20 Series board page.
<p align="left" style="mso-pagination: widow-orphan" class="MsoNormal"><span class="smalltxt1"><a name="Main Gun Function Mode:"><span lang="en-us"><font size="2"> <span style="font-family: Tahoma">Main Gun Function Mode</span></font></span><span lang="en-us" style="font-family: Tahoma"><font size="2">:</font></span></a><font size="2"><span lang="en-us"><font face="Tahoma"> Pr</font></span><font face="Tahoma">ess </font><span style="font-family: Tahoma"> "<span lang="en-us">POWER</span>" key</span><span lang="en-us" style="font-family: Tahoma"> on TV remote to select</span></font></span></p><table width="688" height="456" cellspacing="0" cellpadding="0" border="1" id="table64" style="border-collapse: collapse; border: medium none;" class="MsoTableTheme"> <tbody> <tr style="mso-yfti-irow:0;mso-yfti-firstrow:yes;height:12.8pt"> <td width="40%" bgcolor="#C0C0C0" align="center" style="border:1.0pt solid black; mso-border-alt:solid black .5pt;height:15; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma"> Available Settings</font></span></p> </td> <td width="20%" height="15" bgcolor="#C0C0C0" align="center" style="border:1.0pt solid black; mso-border-alt:solid black .5pt;padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p class="MsoNormal"><span class="smalltxt1"> <font size="2" face="Tahoma">Indicator </font></span></p> <p class="MsoNormal"><span class="smalltxt1"> <font size="2" face="Tahoma">flashes times</font></span></p> </td> <td width="40%" bgcolor="#C0C0C0" align="center" style="border:1.0pt solid black; mso-border-alt:solid black .5pt;height:15; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma"><span lang="en-us"> Description</span></font></span></p> </td> </tr> <tr> <td width="40%" align="center" style="border-left:1.0pt solid black; border-right:1.0pt solid black; border-bottom:1.0pt solid black; border-top:medium none;mso-border-top-alt:solid black .5pt;mso-border-alt:solid black .5pt; height:1; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p class="MsoNormal"><span class="smalltxt1"><span lang="en-us"> <font size="2" face="Tahoma">TAMIYA RECOIL MODE*</font></span></span></p> </td> <td width="20%" align="center" style="border-left:1.0pt solid black; border-right:1.0pt solid black; border-bottom:1.0pt solid black; border-top:medium none;mso-border-top-alt:solid black .5pt;mso-border-alt:solid black .5pt; height:1; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p align="center" style="mso-pagination: widow-orphan" class="MsoNormal"><span class="smalltxt1"><span lang="en-us"><font size="2" face="Tahoma">1</font><font size="2" face="Tahoma" color="#FF0000">*</font></span></span></p> </td> <td width="40%" align="left" style="border-left:1.0pt solid black; border-right:1.0pt solid black; border-bottom:1.0pt solid black; border-top:medium none;mso-border-top-alt:solid black .5pt;mso-border-alt:solid black .5pt; height:1; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p class="MsoNormal"><span class="smalltxt1"><span lang="en-us"> <font size="2" face="Tahoma">To use TAMIYA recoil unit,</font></span></span></p> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma">CN3<span lang="en-us">, Pin</span></font><span lang="en-us"><font size="2" face="Tahoma">4:TAMIYA Recoil Unit Switch</font></span></span></p> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma">CN3<span lang="en-us">, Pin</span></font><span lang="en-us"><font size="2" face="Tahoma">5:TAMIYA Recoil Unit Switch</font></span></span></p> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma"> <span lang="en-us">CN9, Pin3:</span></font><span lang="en-us"><font size="2" face="Tahoma">TAMIYA</font></span><font size="2" face="Tahoma"><span lang="en-us"> </span></font><span lang="en-us"> <font size="2" face="Tahoma">Recoil Unit green Wire</font></span></span></p> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma"> <span lang="en-us">CN9, Pin</span></font><span lang="en-us"><font size="2" face="Tahoma">4:TAMIYA Recoil Unit white Wire</font></span></span></p> </td> </tr> <tr> <td width="40%" align="center" style="border-left:1.0pt solid black; border-right:1.0pt solid black; border-bottom:1.0pt solid black; border-top:medium none;mso-border-top-alt:solid black .5pt;mso-border-alt:solid black .5pt; height:16; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p class="MsoNormal"><span class="smalltxt1"><span lang="en-us"> <font size="2" face="Tahoma">HL AirSoft MODE</font></span></span></p> </td> <td width="20%" align="center" style="border-left:1.0pt solid black; border-right:1.0pt solid black; border-bottom:1.0pt solid black; border-top:medium none;mso-border-top-alt:solid black .5pt;mso-border-alt:solid black .5pt; height:16; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p style="mso-pagination: widow-orphan" class="MsoNormal"><span class="smalltxt1"><span lang="en-us"><font size="2" face="Tahoma">2</font></span></span></p> </td> <td width="40%" align="left" style="border-left:1.0pt solid black; border-right:1.0pt solid black; border-bottom:1.0pt solid black; border-top:medium none;mso-border-top-alt:solid black .5pt;mso-border-alt:solid black .5pt; height:16; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p class="MsoNormal"><span class="smalltxt1"><span lang="en-us"> <font size="2" face="Tahoma">To use HL AirSoft,</font></span></span></p> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma">CN3<span lang="en-us">,Pin</span></font><span lang="en-us"><font size="2" face="Tahoma">4:HL AirSoft Unit Switch</font></span></span></p> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma">CN3<span lang="en-us">,Pin</span></font><span lang="en-us"><font size="2" face="Tahoma">5:HL AirSoft Unit Switch</font></span></span></p> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma"> <span lang="en-us">CN9,Pin3:HL AIRSOFT Motor +</span></font></span></p> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma"> <span lang="en-us">CN9,Pin</span></font><span lang="en-us"><font size="2" face="Tahoma">4:</font></span><font size="2" face="Tahoma"><span lang="en-us">HL AIRSOFT Motor </span></font><span lang="en-us"><font size="2" face="Tahoma">-</font></span></span></p> </td> </tr> <tr> <td width="40%" align="center" style="border-left:1.0pt solid black; border-right:1.0pt solid black; border-bottom:1.0pt solid black; border-top:medium none;mso-border-top-alt:solid black .5pt;mso-border-alt:solid black .5pt; height:16; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p class="MsoNormal"><span class="smalltxt1"><span lang="en-us"> <font size="2" face="Tahoma">HL Recoil MODE</font></span></span></p> </td> <td width="20%" align="center" style="border-left:1.0pt solid black; border-right:1.0pt solid black; border-bottom:1.0pt solid black; border-top:medium none;mso-border-top-alt:solid black .5pt;mso-border-alt:solid black .5pt; height:16; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p style="mso-pagination: widow-orphan" class="MsoNormal"><span class="smalltxt1"><span lang="en-us"><font size="2" face="Tahoma">3</font></span></span></p> </td> <td width="40%" align="left" style="border-left:1.0pt solid black; border-right:1.0pt solid black; border-bottom:1.0pt solid black; border-top:medium none;mso-border-top-alt:solid black .5pt;mso-border-alt:solid black .5pt; height:16; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p class="MsoNormal"><span class="smalltxt1"><span lang="en-us"> <font size="2" face="Tahoma">To use HL Recoil unit,</font></span></span></p> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma">CN3<span lang="en-us">,Pin</span></font><span lang="en-us"><font size="2" face="Tahoma">4:HL Recoil Unit Switch</font></span></span></p> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma">CN3<span lang="en-us">,Pin</span></font><span lang="en-us"><font size="2" face="Tahoma">5:HL Recoil Unit Switch</font></span></span></p> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma"> <span lang="en-us">CN9,Pin3:HL </span></font><span lang="en-us"> <font size="2" face="Tahoma">Recoil </font></span> <font size="2" face="Tahoma"><span lang="en-us"> Motor +</span></font></span></p> <p class="MsoNormal"><span class="smalltxt1"><font size="2" face="Tahoma"> <span lang="en-us">CN9,Pin</span></font><span lang="en-us"><font size="2" face="Tahoma">4:</font></span><font size="2" face="Tahoma"><span lang="en-us">HL </span></font><span lang="en-us"> <font size="2" face="Tahoma">Recoil </font></span> <font size="2" face="Tahoma"><span lang="en-us"> Motor </span></font><span lang="en-us"><font size="2" face="Tahoma">-</font></span></span></p> </td> </tr> <tr> <td width="40%" height="12" align="center" style="border-left:1.0pt solid black; border-right:1.0pt solid black; border-bottom:1.0pt solid black; border-top:medium none;mso-border-top-alt:solid black .5pt;mso-border-alt:solid black .5pt; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p class="MsoNormal"><span class="smalltxt1"><span lang="en-us"><font size="2" face="Tahoma"> Gun elevation servo Mode</font></span></span></p> </td> <td width="20%" align="center" style="border-left:1.0pt solid black; border-right:1.0pt solid black; border-bottom:1.0pt solid black; border-top:medium none;mso-border-top-alt:solid black .5pt;mso-border-alt:solid black .5pt; height:12; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p class="MsoNormal"><span class="smalltxt1"><span lang="en-us"> <font size="2" face="Tahoma">4</font></span></span></p> </td> <td width="40%" height="12" align="center" style="border-left:1.0pt solid black; border-right:1.0pt solid black; border-bottom:1.0pt solid black; border-top:medium none;mso-border-top-alt:solid black .5pt;mso-border-alt:solid black .5pt; padding-left:5.4pt; padding-right:5.4pt; padding-top:0cm; padding-bottom:0cm"> <p align="left" class="MsoNormal"><span class="smalltxt1"> <font size="2" face="Tahoma"> <span lang="en-us">J4.1. Signal( White Wire)</span></font></span></p> <p align="left" class="MsoNormal"><span class="smalltxt1"><font face="Tahoma"> <span lang="en-us"><font size="2">J4.2. </font> </span></font><span lang="en-us"> <font size="2" face="Tahoma">+5V ( Red Wire)</font></span></span></p> <p align="left" class="MsoNormal"><span class="smalltxt1"> <font size="2" face="Tahoma"> <span lang="en-us">J4.3. Battery - (Black Wire)</span></font></span></p> <p align="left" class="MsoNormal"><span lang="en-us"><font size="2" face="Tahoma">*This function is only available on TK22 </font></span></p> </td> </tr> </tbody></table><p align="left" class="MsoNormal"><span class="smalltxt1"> <span lang="en-us"><font size="2" face="Tahoma">*Use this mode on Hooben Tank.
~ Craig ~
~ Craig ~
