Wanted : Tamiya Sensor
...oh I hope this isn't against some rule, i haven't slept for a long time... bwahaha.
Looking for a used or nearly new Tamiya battle sensor for my KV-2. Local is good, Paypal is good
Tried out an Impact at today's meet, didn't fit at ALL (Clark base), Tamiya was perfect. PM me!
It is very rare to see a TBU apple for sale. We ahve a huge parts excahnge at Danville but apples are a rarity. The bases are sold separately as are the emitters and the holders. I have not seen Tamiya sell apples separately. Bases are about $30 at a AAF Tank Museum and the IR emitter about $10(?). Most guys keep one or two for spares. FYI....Impact apples and bases are NOT intrecangable with Tamiya. They look exactly the same but are of different proportions. The apple and base MUST match. The IR emitters are interchangable however.
ORIGINAL: thecommander
The left apple is Impact's, while the right is a Tamiya, & as one can see, they are similar but certainly not the same.
But dang, if the 5 pinout on them is the same for the direction the apple needs to connect to their respectives bases (I thought they were), they look SO close it almost seems like one could use a little blade, some cutting &/or regluing, & the Impact would fit a Tamiya base if that was all you had to use it with at the time.
I can't recall where either, but I thought I did read on some forum where the Tamiya apple will actually fit onto the Impact base, not perfectly, but well enough to use for battle? I could be absolutely wrong on that one though, so don't blast me for mentioning it
~ Craig ~
ON, CANADA
Strato, Tamiya Apple may be more expensive then your TK20...
It maybe a good idea to use DBU apple. what you need do is re-create a connector.
<br type="_moz"/>
<br type="_moz"/>
I've got a spare one in the mail already, problem solved :P
Thank for you all the info though, I will consider DBU / etc for the future.
