vk3601
Old 06-26-2013 | 07:24 AM
Cruiser133's Avatar
Default vk3601
I came across an interesting kit on the Ludwig-hobby site and was wondering if anybody has ever built a vk3601? I have a donor hl tiger to base it on. Any help would be appreciated. I am grinding one on WoT at the moment with the konisch gun and would love to build one if possible.
Old 06-26-2013 | 01:56 PM
FreakyDude's Avatar
Default RE: vk3601
it pretty tough sledding to build the specific parts. I would think a Panther G turret might be easier to use for the turret though. <div>I would sketch out a few different views of what it is you want to do then start with the lower, once the lower is complete then build the turret to fit.</div><div>As your turret is going to be really small I would think 2 Hitec  HS81 servo's will fit the bill for the elevation and recoil.</div><div>plan your elevation unit  to hang in the turret hole and push the gun up or pull it down via a linkage.</div><div>I would cut down or add to existing parts and try to stay away from scratching this unless you have a solid plan on how it all goes together. </div><div>Remember maintenance is key, all your major parts must be removable for repairs.</div><div>
</div><div>this will certainly test your build skills regardless of who you are. I wish you luck and if I can offer any help don't hesitate to ask.</div>
Old 06-27-2013 | 10:00 AM
Cruiser133's Avatar
Default RE: vk3601
Thanks Freaky. It looks like the Ludwig site used a HL Tiger lower as the basis for the upper VK3601 kit. I was thinking the same on the Panther turret. It looks close enough as far as I can tell. Has anybody ever built one yet or done a build report?
Old 06-27-2013 | 05:00 PM
Strato50's Avatar
Default RE: vk3601
I'd like to know more about it too, it's a great looking tank and has the potential to really tear up the field.
It's also one of my long time favourites in World of Tanks.
Looks like they cut down a set of plastic Tiger tracks or used a set of 'transport' tracks, the Vk3601 were somewhat narrow compared to a Tiger.
Old 06-28-2013 | 02:34 AM
Default RE: vk3601
hello
I m Producing 2 diverent versions of this vk3601 kit. one using the Heng Long lower hull and one is a complet kit.
look here.
and here the big one
if you have any questions let me knew :-)
cu christian
Old 06-29-2013 | 05:33 AM
Cruiser133's Avatar
Default RE: vk3601
Thanks Christian, I sent you an email for a total shipped for the upper hull assembly. I have some HL tanks in various stages of disassembly from my other projects that I will use for this. Does anybody have a good supplier for a complete Panther turret/mantlet/barrel assembly?
