Can DMD and MFUs be mixed?
I have the FO Sherman DMD and MFU in my T-34. I would like to get Russian sounds in it with the KV-1's MFU-06.
Is it possible or would I need the matching KV-1 DMD too?
Sweet, thanks guys.
I have servo recoil on it now and an extra Tiger recoil unit. I'm not sure I want to go poking around right now, but that may be a future operation.
JCRC has the MFU-06 for $142. I can hook up some lights then too.
All the MFU less the Sherman one have recoil. Even the M51.
The best one if you ask me is the Pershing as have lights function, but of course if you are looking for russian engines there is not other option in Tamiya range.
The KV/JS-2 one has functioning brake lights as well as the headlight. so it'll cover everything I want it to do.
I tried the JS-2's MF in the T-34 and it works perfectly. Great sound and since the JS-2 doesn't have a brake light, I'll use the harness in the T-34 and make a four SMD harness for the JS-2's running lights.
I just used all the Tamiya electronics for their KV-1 for my T-34's. I love the gear engagement function on it like the Pershing has and the engine sound is one of Tamiya's best I think. that DMD /MFU set up may be a little less expensive than the JS-2 also.
