frequency change, halftrack
Hi Guys,
I've got one of those Torro 1/16 halftracks and I'd like to run a pair but I hear you can't run them two at a time as the frequencies are the same in all units. Does anyone know how to go about changing the frequency in one of them? I'd even be willing to go with a better TX/RX system if I could find one that would work with a minimum of hassle. I'm pretty new to this stuff so I don't want to get in over my head. I just wired up a mato all metal panzer, though, so I do know a little. Damn little. :-) So what do y'all think? Can it be done? Two halftracks running side by side?
Gary
Gary
I have 2 as well... both are on a different channel.
Have you double checked?
Jeff
Jeff
Hey Panther (cool handle),
Thanks for the info. No, I haven't checked, I'm going on the word of the guy that sells them. Maybe I'll just buy another and see what happens, but it would sure be nice to know I can fix it if I have to.
I do not know if it is 27MHz or 2.4 GHz but 27 MHz allows a choice of crystals and 2.4 GHz gives each unit a unique channel when you initialise or bind the transmitter when you operate it for the first time. Am I off your point or have I actually helped????? shaun
You are correct. Rc crystals usually look like this:
http://everything-rc-cars.com/images/rc-crystals.jpg
And have the frequency marked on the tag. I don't have any experience with the torro halftrack, but usually there is a spot where you can swap out crystals on controllers if its 27mhz. Just check and see what the frequencies are for each. If they are the same, you can just buy some different frequency ones online.
All the RC halftracks I have ever had and sold have been on the same channel 27 AM. Even the older ones. These are super RC models for their price. Metal suspension, all rubber tires, even on the boggy wheels...LOL. The front leaf springs would be easy to make functional but very few guys know that it does have a front coil spring suspension....check yours guys. Real servos for the steering and gun elevation. The drive shaft and differential are very high quality. A very nice dashboard and many details in the cargo/gun area. The four M2 gun barrel are brittle but the gun carriage swivels 360 all day long. The radio range it not very good but the front headlight and tail lights make up plus the bonus of the two really detailed and pose-able figures. There is even a plug for a NMHi battery pack to eliminate the AA batts. There is a heat sink on the motor to keep it cool. note the screw from the factory stuck to the magnets.
There is a crystal soldered into the TX, but the RX is built into the board. Here are a few pix.
If you want one drop me a PM... but don't wait long! I have some parts too.
Hey bob, is their anyway to change the half-track over to a 2.4 or put in a new radio system? i've seen that guys have done it before but i'm not sure how to do it. thanks -sean
Yes, you may want to take a look at Clarks TK35 as an option. It is small!!!
All the RC halftracks I have ever had and sold have been on the same channel 27 AM. Even the older ones. These are super RC models for their price. Metal suspension, all rubber tires, even on the boggy wheels...LOL. The front leaf springs would be easy to make functional but very few guys know that it does have a front coil spring suspension....check yours guys. Real servos for the steering and gun elevation. The drive shaft and differential are very high quality. A very nice dashboard and many details in the cargo/gun area. The four M2 gun barrel are brittle but the gun carriage swivels 360 all day long. The radio range it not very good but the front headlight and tail lights make up plus the bonus of the two really detailed and pose-able figures. There is even a plug for a NMHi battery pack to eliminate the AA batts. There is a heat sink on the motor to keep it cool. note the screw from the factory stuck to the magnets. There is a crystal soldered into the TX, but the RX is built into the board. Here are a few pix. If you want one drop me a PM... but don't wait long! I have some parts too.
Greg
AB, CANADA
I put a new radio system in mine and used an RX18, DBC3 and Benedini to bring this model up to a radio system it deserves. As Bob mentioned it is a really good model, and I wish I had bought another one when Hobby raw was blowing them out for cost.
I lost the Quads though and went with a tarpaulin cover on mine
Hey Jim,
I see Bob sent you a message about getting a halftrack. That's where I got mine and I was very satisfied. Bob's pretty cool, but the important thing is that I've found him to be honest. I'm trying hard to have the money for another halftrack by the middle of this month. So if you're reading, Bob, I'm still on it so I hope you're still holding me one. :-)
Hey Jim,
I am sorry but I did not see this question until today. I guess you are enjoying the M16 you got at Danville. Yes, these can be upgraded. ElMod used to make a system but I don't think it caught on. I have never seen one with that system. I am rebuilding the M3 Halftrack that I have used at NEAD events & Danville as a camera platform. It will IR battle with a DBU system. The Tamiya takes up too much room. It will be a light but fun none the less. It had a good normal hobby quality servo for the steering and elevation. Traverse is continuous via a contact plate and gear reduction. Stay tuned. More to come.
I have 1 in service, plus one under construction - they ain't cheap, but they do work well.
Read carefully.....I said they used to make one.... but never said that they stopped Martin. LOL.That board was definitely not popular.
Reving up for the Europe trip yet? Know what is missing from this picture. YOU!
You and your mate did make this one. David Fletcher sure does make us look tall doesn't he?
liar, liar, pants on fire there Bob - you can still get the boards, tho you have to solder on the socket for the CSI these days...
So yes, to answer your comment in the PM the other night - your English could indeed use some work
Joking aside, I suspect its not popular due to the cost (over 200 euro's for the full board + CSI) and limited availability, a pity as its pretty good value when stacked up against the cost of DMD + MFU + TBU, with the extra added bonus that the boards are small enough to fit without looking too out of place.
Ah, but you are using the past tense when you say "they used to make one" - that implies that they do not any more...
You never cease to amaze me Martin. Looking forward to this summers trip abroad. Did you start the countdown yet?
