Removing Drive Shaft
Old 12-26-2014 | 05:18 AM
Default Removing Drive Shaft
Hey Guys,
On the standard Taigen gear boxes, how do you remove the drive shaft. I have a set of steel gear boxes with a drive shaft too long for my Tiger, so I want to use the drive shaft from the pot-metal boxes that came with the tank.
Can't seem to figure it it.
G
Old 12-26-2014 | 06:21 AM
Front yard Shade-tree version....
Just did this with the new HL full bearing gear boxes, converted to a final driven taigen shaft (larger diameter sprocket interface):
split the gearbox (4 screws),
remove final driven shaft/gear,
I used a spring center punch too loosen the pin that holds the gear on the shaft, drove it out with "old" drill bit (now it's a drift). HL pin note: look for the side that has a chamfer this is the side you want to drive the pin from the other side is knurled. Taigen are knurled in the center.
Then using a 3/8 drive 13mm deep socket supporting the gear -drive (press, arbour, vice or hammer) the gear off the shaft.
Reverse process to assemble.
Found that one of the shafts wasn't drilled centered for the pin, so the pin didn't fully seat flush so it needed to be ground so not to interfere with the last drive gear.
Also I learned that clear plastic tubing (like the smoker) can replace any spacers on the shafts, HL uses this method -it actually puts a slight pre-load on the end play -great stuff, Taigen uses aluminium tubing.
Old 12-26-2014 | 01:36 PM
Hey Greg, Haw Haw's method sounds very good, but if you still can't get it PM me and I'll make a video showing exactly what you need.
