Poor Design of T-34 by Taigen >
Old 05-29-2015 | 09:26 AM
  #51
ausf's Avatar
Originally Posted by sergeantseabass
well it sounds like the T34 is going to be a tank of a tank on the battlefield once it is all said and done. Not to bogart the thread but your issue got me thinking about my JS-2. Now my lower hull is metal and the idler system is attached to the hull. there is only a small piece of metal that is used to help brace the hull. The lower glacis is just plastic and is a failure point for the JS-2. So to try to help corret his I added a piece of aluminum angle to mount attachment to the idler and lower glacis. My hope is that the angle aluminum will help to brace this area and prevent any camber problems that might be caused once I upgrade the tracks and motors. I'll start a seperate thread on it in case any of my other fellow JS-2 owners want to throw thier thoughts on it or even try it out for themselves.
Bill
Bill,
Just as a reference point, my JS-2 got knocked off a table at an event (before it's first shot was ever fired) and landed on the idler. It was bent in. About 5 minutes with a set of needle nose and I was on the battlefield. For over a year it's still going strong, tracking straight with no ill effects or need to brace and it's usually driven by my 13 year old son over all types of junk.
I would ask around about going with metal tracks on this one. Most battlers avoid them except with the Pz III/IV where plastic may be too weak. There's a lot of meat to the Tamiya JS-2 links, really no need to beat up things by running metal IMO.
Old 05-29-2015 | 10:20 AM
  #52
Originally Posted by ausf
Bill,
Well The reason that I was planning on going with metal tracks and slightly larger motors has more to do with the drive. During the last battle weekend I was able to bring my JS-2 out and break the cherry on it's battling. it is a beefy tank and I am happy with the drive for the most part, however it is a bit bouncy when crossing bridges or going over hills. Now another tanker had brought his JS-2 as well that he has been using for a couple of years now. Besides the obvious weight difference the drive of his JS-2 vs mine was very noticeable mostly with the traversing of hills and bridges. the addition of the metal tracks and then upgraded motors kept the speed about the same but added the weight to take the bumps a bit smoother and extra torque to keep the tank moving smoothly.
Old 05-30-2015 | 07:23 AM
  #53
dlobmwm3's Avatar
Bill,
I would NOT recommend metal tracks as per Daryl Turner and his experience with tanks over the years at Danville. One of two things will occur, either the gearbox will go from stripping of the gears or infrastructure of the hull. This was the main reason I pulled off the metal road wheels and metal tracks off of the Taigen.
