Taigen recoil unit question >
Old 06-04-2015 | 05:06 PM
Herman,
You can use what ever emitter that you want with the Mako. No need to change it out. I'm going to be using the impact emitter that i still have for mine. As far as the fire every three seconds that is going to be when your really going to want to test the IR. My Sherman would continue to fire but the IR itself won't go off until evey five seconds. That has more to do with the fact that the Mako is just a board used to give you compatability between the different systems. when you start your test you'll find that even if the tank itself fires every three seconds that the IR does not.
It might be easier to use the tamiya one since you don't have to worry about placing the right wires in the system but it isn't required The Mako will just send a "fire" signal to the IR ports that are on the board.
Bill
Old 06-04-2015 | 05:34 PM
Green Amphibian's Avatar
OK Bill. I tested the IR and you nailed it. Tank fires, but there is no IR signal sent. The IR only fires after 5 sec. It takes nine hits to kill it now also. Thanks much for the help and now I can finish installing everything on the inside and have a Jagdpanther ready for the next battleday.
Happy Herman
Old 06-04-2015 | 05:52 PM
good deal glad I could be of some help to you
