Headlight I made for Henglong KV-1
I have a before and after picture. The headlight was made by putting 1 layer of tinfoil over a marble, the coating it with 2-part epoxy. The lens was cut out of an old cd case and after being cut to shape I scraped the lens pattern with a razor knife. The headlight guards are made from thin brass rod. I used the original led bulb and mounted everything using brass tube. The weathering looks weird in the pictures, but in real life looks good.
Looks great to me and the satisfaction that you made it yourself is always priceless!
Jeff
Jeff
