First tank choice
What do you guys think about this shopping list:
- HL Pershing with smoke and sound
- 4.1 PRO STEEL GEARBOXES PERSHING M26 380 MOTORS/18.000T
http://www.rctank.de/41-PRO-steel-ge...-motors/18000t
- T- 81 Pershing tracks
http://mitosal.com/1011.htm
- M26 Pershing metal road wheels, idlers and suspensions
http://tankarmy.com/heng-long-tank/p...khpq47nqdj77q5
- M26 Pershing metal shock adsorbers with springs
- 360 deg rotation upgrade kit
That's a good upgrade order. Remember, you want to come up with a form of hull bracing when you go and start putting metal parts on it.
Now I'm confused - some sellers say they fit Tamiya and HL tanks ;/
I believe Tamiya have two flat spots on their driveshafts compared to Heng Long's one. A little dremmel work should be enough.
Actually, now that I think about it, even the HL/Taigen metal gearboxes/sprockets need some minor dremmel work to fit properly. They're too tight otherwise and are hard to take on and off.
#34
I'm back with another question
I got the S&S version - it runs great But is there a way for it to generate more smoke? Any mod?
Right now, it does smoke, but It would be great if it would smoke more, or generate more dense smoke - I'm using the oil that came with the tank, (maybe there's a better one out there?)
