Battery charger question
Guys,
Over the years, I have managed to collect quite a few different 7.2v batteries from Ni-CD to NiMh and 1100Mah to 5800mah. I have one multi-charger but it is a drag to wait on it to charge. What strategies do you guys recommend to quicken the process? Is there a better/quicker charger out there than my Imex B6?
You can charge at a higher amperage, but you need to make sure your battery can handle it. Usually 1C is safe, but some older batteries might not be too happy with the rate of charge. Also remember fast charging does kill your battery faster. Do what I do and just keep a large stock of them and get a big charger and parallel charge them. Check out www.bateryuniversity.com if you got any questions on batteries, they have quite the wealth of information there.
https://www.google.com/search?q=hobb...C8K6mwG_3bHwDw
This will charge 4 batteries at once. My buddy has one its pretty nice
That's a good looking charger, Harley, but it's cheaper straight from hobby king.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
