Tamiya M26 Light Unit
Old 04-22-2016 | 05:19 PM
PanzerschreckLeopard's Avatar
Default Tamiya M26 Light Unit
I'm a bit confused on how to assemble the light unit for this tank. The instructions, like this pic, show one plug and three tiny LEDs. But what I have is two plugs and two large LEDs that will clearly not fir through the hull front openings, and nothing else in the box looks more like the one in drawing. Am I doing something wrong, or wrong part,or what?
Old 04-22-2016 | 10:42 PM
That looks like the more modern lighting unit I have with the is-2. It uses fibre optics to take the light to the head and tail lights. The normal Pershing unit should have four tiny bulbs
Old 04-23-2016 | 04:19 AM
Tanker 10's Avatar
Yes, one bulb and two pieces of fiber optic for the front and rear. Mine had a supplemental instruction sheet for the new light unit.
Old 04-23-2016 | 04:38 AM
Ahh, i found the sheet. There's one very long piece of fiber optic, do I just cut it into four even pieces?
Old 04-23-2016 | 04:53 AM
I had to do this to my Pershing after the original lights burned out. I ran all my light wiring and made sure I had it where I wanted. Then I just cut the fiber optic individually. You only get 1 piece so you want to make sure its right before you cut. I think most of the Pershings only run 1 tail/Brake light, Rear Left. I bought some some more fiber optic and added the Rear Right Tail/Brake light. There is a bit of trial and error positioning the fiber optic in the headlights. The position of the fiber optic in the headlight will change the lighting affect. I positioned (in the dark) where it looked the best and then just put a drop of glue on it to hold it in position.
Old 04-23-2016 | 05:15 AM
Tanker 10's Avatar
Perfect description on how to do it Shorty54.
Old 04-23-2016 | 07:07 AM
In my Sherman I replaced these two LED boxes and light fibers with just 4 SMD LEDs. It works much better. I just cutted off these boxes and soldered instead of them 2 red LEDs for the rear and two warm white for the front.
Old 04-23-2016 | 09:46 AM
Right, well, I found the sheet and got them done. It said to cut them into three even 100mm pieces. Thanks guys! Just one small step left and then I can start on the turret...
Old 04-23-2016 | 11:18 AM
Tanker 10's Avatar
You're going to like that tank.
Old 04-23-2016 | 11:23 AM
Now to hope I packed the wires in tight and not bind up the turret !
Old 04-23-2016 | 11:32 AM
There's a webpage with rear light description:
http://www.mikereidconstruction.com/...ail_Lights.htm
Maybe it could be usefull....
Old 04-23-2016 | 02:08 PM
Doesn't matter, the clip for gun elevation decided it would much rather get lost so that I have to buy more, so that THOSE can fly off and get lost, until I've spent the cost of the tank itself just of spare parts that still prefer to get lost and lost adn lost...
Old 04-23-2016 | 06:57 PM
Has happened to all of us. Grab yourself a cry towel (just a dish towel if need be) to put underneath your build. Wont stop things from flying up away from ya, but if something drops it'll dampen the fall and your screw, bracket, washer, etc doesn't go missing.
Old 04-24-2016 | 04:20 AM
Ahh thanks...seriously though, how do I get that little C-clip onto the cannon elevation motor? It just refuses to go on, and it was to small to spread it apart AND push...
Edit: Finally got it on! Yesssssss
Old 04-24-2016 | 04:41 PM
Lat things, how do I arrange these wires so not to bind up the turret? Test drove it and turret would only turn slightly before clicking. Also, what holds the mantlet in place? I can;t find anything on that in the instructions, so it just slights forward whenever.
Old 04-24-2016 | 05:07 PM
Tanker 10's Avatar
Take a look at page #28, step #41, then F6 and F13. I used shoe goo to hold them together incase I ever wanted to separate the two.
I use scotch tape on my wires coming out of the turret. I bundle them and then tape every couple of inches. I leave the flash unit cable out of the mix. When I put on the top hull, I allow the bundle to make kind of a circle towards the rear of the turret.
Old 04-25-2016 | 04:30 AM
There are some good write ups on the Pershing wiring arrangement, just search for them. Here is one that Bob does,
http://www.rctankcommand.com/before-...er-photos.html
Old 04-26-2016 | 06:20 AM
The best wire management tip for the Pershing is to cut the speaker box so the battery slips into it. That will give more room for the bundle in the hull. You will also want to open the loaders hatch and pull as much wire into the back of the turret as needed.
You can get away with the last tip and not cut the speaker box. I did that on my last pershing, but I'm going to cut the speaker box on this one also.
Old 10-22-2018 | 01:55 PM
Bringing up an old thread... sorry!
Just got second hand Sherman with a new light unit, why does this light unit have two cables?!
i presume only the three pin plug works and it will only work with a dmd that has a light socket?
My new Sherman has super Sherman dmd and mf so no light socket but it has these installed so wondering if the two pin was used to power it?
Adam
Old 10-22-2018 | 02:04 PM
Maccrage's Avatar
Here is the supplemental instruction sheet that comes with tanks with the new light unit. Different plugs for the 3 pin depending on the MFU, but the 2 pin goes to CN5 on all of them.
Old 10-22-2018 | 02:07 PM
Perfect thank you.
just got to work out where to put the 3 pin now as the super Sherman dmd doesn’t have a 3 pin socket lol
unless it eorks with hust the two pin. Time to try
