Work on measuring out plates for rc 1/16 m1917 tank project
I asked for help on finding specific dimensions, but to no avail, so i decided to take matters into my hands and start finding the measuremente myself by converting measurements from a unlabeled blueprint, converting them to 1:1 measurements, and then 1:16 measurements
Could try contacting Eric Scott on his FT-17 build. He may have some info. He's on this forum as well, his handle is Heavyaslead.
Also is the static you could grab for referrence.
http://southeastarmoreddivision.weeb...-17-build.html
http://www.ebay.com/itm/TAKOM-1002-1...EAAOxyyq5TNaTK
Thanks so much BennyB, this is immensly helpful!! Also, do you know how i can get blueprints blown up to 1/16 scale? They say they are currently 1/35 i believe, and i can manage with the current size in terms of measuring it out, but a larger 1/16 blueprint would make life easier
Just note the American version (m1917) had variations to the French design.
If you have a chance the AAF Museum in Danville, Virginia has a rather good condition real American version to look over, they may even have documentation with it...
Thanks for chiming in Eric.
Sadly, i live all the way in Missouri. The closest M1917 was in Indiana, which was less than a hour drive to the Ropkey Armor Museum which owned it. Then they sold it so now i have no location nearby
You could also use a set of dividers or calipers and have a preset legend. In other words measure the 1/35 part with the dividers then go to your legend which is converted to 1/16 scale length divisions...there's your distance. Think of a navigation chart and tools.
The only issue is that i have the picture, but dont know whether the one that is fitted to the page is the 1/35 scale. Ill get the real dimensions and divide it by 35, then measure the printed photo to check its accuracy. I may have to photoshop the blueprint to get it to 1/35 scale then. Or i could even blow it up to 16th scale
