Tamiya Abrams M1A2 Rebuild, Repaint + Working RC Setup. >
Old 04-15-2018 | 09:43 PM
Pcomm1.v2's Avatar
Default This is who to contact at Tamiya USA
Originally Posted by crxsidan85
mine also shuts down when firing the main gun. I partially built the tank and havent finished it due to frustration. I am using the 2.4 futaba skysport . Its a great tank but the electronics arent the easiest to figure out
Tamiya USA is aware of the Futaba Skysport 2.4 compatibility issue with the Abrams Kit.
They offered me no solution or fix other than to suggest I change radios and that DID NOT work, because something else failed!
The Tamiya Attack Radio System did work ALL the transmitter tank functions normally, for about a dozen cannon fires and then it didn't!
I am 99.9% sure I have a faulty turret control unit and I think you do too!
Please contact Gary at Tamiya America about your Abram's turret control unit problem.
Gary Demory
Customer Service Supervisor
Tamiya America
Customer Service
36 Discovery, Ste. 200
Irvine, CA 92618
Gary Demory
[email protected]
1 (800) 826-4922
Regards, John
Old 05-06-2018 | 10:30 AM
Pcomm1.v2's Avatar
Default The fix!
The Tamiya USA email, May 4, 2018, below.
The gun firing shut down problem is fixed!
I did not have the rear light harness hooked up to the “chassis control unit”. So, my fault, builder error, but no mention of that in the assembly and or ops instruction manual. Now we know though, LOL. Enjoy, John
Tamiya USA email:
Hi John,
OK, here's what we found, both your systems set and work as they should. Here's the big BUT, if you DO NOT have all the components hooked-up to the Chassis and turret control units the system will shut off when the main gun is fired, we believe this is a build-in safety feature. When we installed your systems into our runner tank and hooked up everything, both worked great. Once you complete the set-up in step 30 of the manual, I know it's tempting but do not fire the main gun. Both your systems are now set to your radio transmitter, all you need do is finish the kits, and do not fire the gun until everything is hooked up!
Thank you,
Gary
Tamiya America
Old 05-06-2018 | 10:32 AM
Well damn
Old 05-06-2018 | 11:36 AM
Pcomm1.v2's Avatar
Default Friends Abrams electronics defective.
...and my build goes on...though, my cross town friends Abrams electronic package is defective and Tamiya USA will replace it with new parts.
Old 05-07-2018 | 04:33 AM
I hope your issues are finally solved John!
Shad
Old 05-07-2018 | 04:57 AM
  #31
Pcomm1.v2's Avatar
Me too.
Old 05-07-2018 | 08:25 AM
  #32
RichJohnson's Avatar
Quite interesting, these things are nearly computers now in their functionality.
Old 06-16-2018 | 02:22 PM
  #33
Pcomm1.v2's Avatar
Default All good!
Shad
Tamiya USA actually replaced the Chassis Control Unit, but did not admit it, LOL.
So, it is alive and well now, after a lengthy delay.
Old 06-16-2018 | 03:03 PM
  #34
Great to hear John!
Very nice tank!
Enjoy,
Shad
Old 06-16-2018 | 04:19 PM
  #35
Pcomm1.v2's Avatar
Thank you!
John
Old 06-18-2018 | 09:57 AM
  #36
Very nice.
Old 06-19-2018 | 09:15 PM
  #37
Pcomm1.v2's Avatar
Default Tamiya Abrams M1A2 RC IR Setup Idiosyncrasies.
With TBU and LED Emitter Clip On Device.
The following tips assume your model is setup per both manuals, everything is plugged in and "all operates to spec", but now it doesn't, with the TBU & LED Emitter installed!
1. Issue. Fresh Battery Swaps with the Tamiya Battle Unit and LED Emitter plugged into the Turret Control Unit.
Your Abrams now shuts down after firing the main gun. The work around FIX: The model is turned off. With the fresh charged battery connected, unplug the Tamiya battle unit receiver base and the LED Emitter from the Turret Control Unit and then correctly plug them both back in. This procedure will restore firing the main gun, without the resulting shut down.
2. Issue. The volume control at the Chassis Control Unit is turned up as loud as possible. When firing the main gun, the model shuts down. The work around FIX: Lower the volume slightly, until the model does not shut down after firing the main gun.
3. No clue as to why these two glitches occur, but at least there is a work around solution without out having to suffer through Tamiya USA's email nonsense!
4. The good news is the Abrams model, once RC setup, is a fine backyard runner and gives and takes hits nicely. Plus, it handles rough driving at the hands of both enthusiastic kids and clumsy adults; OK.
Enjoy, John
Old 06-29-2018 | 06:49 AM
  #38
texchap's Avatar
Well, everything works on the Abrams, except, I have had to dial back the turret rotation on my Airtronics radio. Anything above 50% on the channel setting the turret rotates non stop in the direction I signal and continues until the switch activates, the sound shuts down and the tank basically resets itself. It is an out of control rotation. Even at 50% if I firewall the stick in any direction it's rotation is out of control. I do have the Tamiya radio coming today, that should solve the issue, I can't understand why this is an issue though.
Old 06-29-2018 | 08:48 AM
  #39
Pcomm1.v2's Avatar
I experienced the same glitch using a Futaba Skysport 2.4 radio system. After switching to the Tamiya Attack 2.4 with the “updated” receiver that strange issue went away. What remained was the main gun firing, tank shutdown issue using the Tamiya Attack Radio. Besides NOT having the rear lights hooked up, my builder bad, the kit’s Chassis Control Unit was faulty. Tamiya USA emailed me an additional rc setup instruction, which is DO NOT fire the main gun until all components are hooked up! They stealthily replaced my Chassis Control Unit (the board in the hull), whatever, the Abrams works now.
Tips: Read the “Idiosyncrasies post” above concerning fresh battery swaps, another and different tank shut down issue, LOL. Just when you think your all rc setup good, something new pops up. An easy fix though. I did alert the Tamiya USA tech about this issue, from first contact. They did not address the issue, at least not for my kits. Probably glitch information overload relative to their capabilities to deal with the known issues. Plus, the Tamiya supervisor was defensive and not willing to admit the Abrams electronics had issues and focused only on setup procedures and not firing the main gun until all components are plugged in and ready to go. Of course, that is really important, but not the whole story or fix if a board is bad!
John
Old 06-29-2018 | 09:06 AM
  #40
Maccrage's Avatar
Almost makes me wonder if they did any qc testing at all. Awful lot of bugs. Almost like Tamiya was in a mad rush to get the Abrams out by some hard deadline no matter what.
Old 06-29-2018 | 09:59 AM
  #41
Pcomm1.v2's Avatar
By observation, it seems to my rc modeler eyes that the Abrams electronic components package (like the Tamiya Type 10) is cheaper and down graded when compared to the Tamiya WWII tank rc electronics and the Tamiya Leopard 2A6. For instance, some of the wiring gauge used in the Abrams is flimsy cheap, some of the male, female plugs are inferior quality, soldering while clean is not robust as within the WWII rc tanks electrics, etc etc.
The Tamiya Abrams rc tank sound effects accuracy is Clark toy like wrong. Most glaring incorrect, especially the Abrams’ brass shell ejection sound effect. The Abrams M1A2 does not use brass shell casings Very poor technical research on Tamiya engineering’s part. I would hazard to guess Tamiya out sourced the Abrams electronics package to Clark and if so they are over charging big time for this low quality electronics package used in the Abrams modern rc tank kit.
That hunch stated, I still enjoy both my rc Tamiya Abrams and a new favorite.
John
Old 06-29-2018 | 10:11 AM
  #42
You could always buy a cheap henglong and build it yourself how you want.
But you have already done that John.
You should see mine in ludicris mode, its fast but not fast enough to jump. Need bigger motors!
Old 06-29-2018 | 10:22 AM
  #43
Maccrage's Avatar
Well, at least the shell ejecting will be right for my M1 I'm going to make from my HL Abrams. I'm going to keep the Tamiya stock.
Old 06-29-2018 | 10:30 AM
  #44
Pcomm1.v2's Avatar
A build brief opinion.
Yes “nothing but trouble” Tamiya Abrams rc tank building fun ate up eight months of on and off hobby fun. Plus your right, not much difference, in my opinion, between a well rebuilt RTR HL RC Abrams and a well assembled stock Tamiya RC Abrams Kit.
Thoughts on RC Abrams tanks after doing a couple of upgrade HL and Tamiya Abrams: Buying an Abrams M1A2 INFRARED RC Model Tank; which one should I GET? Should I buy the Heng Long RTR Abrams and modify it to be Tamiya IR RC battle compatible or buy the Tamiya Abrams RC Kit?
1. The IR RC Project Build Cost Estimate.
A. From Taigen USA.
Heng Long RTR BASE Model Abrams. $200.00
ELMOD (electronics package upgrade). $280.00
Tamiya pair of 380 motors. $20.00
2.4 Four Channel RC System. $100.00
TBU. $98.00
Paint & Supplies. $35.00
Total Build Cost EST. $713.00
B. From the AAF Museum.
Tamiya Abrams Kit. $970.00
2.4 Four Channel per Tamiya USA Spec. $200.00
TBU. $98.00
Total Build Cost EST. $1303.00
C. The COST difference between the Heng Long RTR Abrams with really good basic infrared RC upgrades and a BUILT Tamiya Abrams Kit is estimated to be $590.00.
D. There is a clear qualitative and performance difference between the two builds. The Heng Long build path is a "good enough direction" for an outdoor, to be abused RC IR fighter.
E. If budget is not an issue, take the Tamiya Abram's Kit path, as the qualitative and performance differences favor Tamiya. Though, the HL is close enough for good outdoor battle play, when both models are performing side by side.
F. A TIP: The Tamiya Abram's durability is unmatched and will be running good long after the Heng Long Abrams fails and falls apart.
Though, there is nothing inferior with using an expendable, inexpensive, replaceable HL base tank philosophy. Just replace with a NEW HL Abrams tank, swap out your metal parts, and paint it; when the hull and suspension fails on your worn out HL Abrams; reinstall your upgraded electronics in the new HL Abrams and your back in RC IR business, I have!
Enjoy, John
PS Still haven’t launched my Tamiya Abrams off a ramp to get it airborne and try and score an IR hit. But I will and that drill should be part of the San Diego Modern Tank Battle Day.
Old 06-29-2018 | 10:56 AM
  #45
texchap's Avatar
I have the HL Abrams converted to USMC M1A1. I have the DBRC4 and Benedini. Between the 2 the Tamiya just seems of higher quality overall (torsion suspension, metal arms, bearings, excellent recoil, awesome gearbox etc.) The HL has some issues also. The DBRC4 is very picky when it comes to power. I have a new battery in it even with this it has started to shut itself down after a few minutes of running. If I battle the HL I will need to add the back up battery pack for the board. Up side is DBRC4 plays the Marine Corps Hymn LOL. Overall the Tamy is just better.
Old 06-29-2018 | 11:19 AM
  #46
Pcomm1.v2's Avatar
That is Great! John
Old 06-29-2018 | 11:31 AM
  #47
Pcomm1.v2's Avatar
The M1A2 shell ejection sound effect inaccuracy is a minor point and probably no other rc tank modelers will care, LOL.
John
Old 06-30-2018 | 10:52 AM
  #48
texchap's Avatar
John
Made the switch to the Tamiya 2.4ghz radio. It still has the rotation glitch if I hold the stick too long, so I have to move it a bit at a time. I have no idea why this is happening. It is like it just doesn't want turn off. When this happens it occasionally doesn't want to turn the other direction. This is clearly a Tamiya electronics issue. I have done the setup as per instructions and I am using their radio, so that is not the reason.
Old 06-30-2018 | 11:06 AM
  #49
Pcomm1.v2's Avatar
Question, you did not fire the main gun until every rc set up task was completed? If so, I think your kit’s turret control unit and the chassis control unit are at fault and require replacement. Contact Tamiya USA and request replacements. Be prepared to send them both your units.
John
Contact:
Gary Demory
[email protected]
Tamiya America
Customer Service
Irvine, CA 92618
800 826 4922
Sent from my iPad
Old 06-30-2018 | 01:14 PM
  #50
texchap's Avatar
Figured it out. It was the turret rotation limiter switch. I have never seen Tamiya use it before. I noticed that the runaway rotation started at either the 10 or 2 position during the rotation no matter how slow I rotated it. If it started at the 2 o'clock position it would run to the 10 o'clock position and visa versa. Double checked the plug in location, promptly shook my head and realize reading the other manual helps. I had plugged it into the wrong 2 pin location. Corrected! All is running perfect! This was not a Tamiya error but a builder error.
