Look for how to build a target module >
Old 03-25-2019 | 10:34 AM
Default Look for how to build a target module
I looking to build a target module that could be attached to different devices. It could be attached to a building and movable flag for capture the flag or support trucks. Anyway you get the ideal. I have seen them here but never are the details given on how to build them. I can solder and know the difference between a resistor, cap and transistor. So really I just need a list of parts and their source and maybe a basic wiring diagram of some sort.
Old 03-25-2019 | 03:06 PM
Tankhobby's Avatar
Use an infrared detector with a 38Khz modulation frequency (40Khz will work also) if you can't get this RadioShack part. Pay attention to pin out if you use a different part, they differ between manufacturers. The 1M and 1uF will give you the flash time when hit. The 180 ohm is current limit for the LED. The 22uF is a filter, a .01uF in parallel next to the IC and detector wouldn't hurt. Shield the detector from ambient light, sunlight, camera flashes and other infrared emitters otherwise it will always flash. I recommend testing indoors in a dark room first.
Old 03-26-2019 | 02:43 AM
Originally Posted by Tankhobby
<img src="https://cimg8.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/339x121/detector_circuit_acb7f09ffa649f743ea6d09c71c0dbfae ddb607b.jpg"/><br /><br />Use an infrared detector with a 38Khz modulation frequency (40Khz will work also) if you can't get this RadioShack part. Pay attention to pin out if you use a different part, they differ between manufacturers. The 1M and 1uF will give you the flash time when hit. The 180 ohm is current limit for the LED. The 22uF is a filter, a .01uF in parallel next to the IC and detector wouldn't hurt. Shield the detector from ambient light, sunlight, camera flashes and other infrared emitters otherwise it will always flash. I recommend testing indoors in a dark room first.
<br /><br />Very interesting. Do you have more info about it? Posibility of adding sound?<br />
Old 11-17-2019 | 08:17 PM
Thank you for this, sorry for the late reply. Working on sourcing the items which does not appear to be a problem.
Old 11-23-2019 | 08:25 AM
Tankhobby's Avatar
Take the output that drives the LED and have it trigger a sound module. A simple reed switch can act as a relay an activate any other device.
Old 11-30-2019 | 06:56 PM
I have found a sound board that could be added. Working on basic board first.
Old 11-30-2019 | 10:07 PM
Following with interest!
Old 03-25-2020 | 08:36 AM
Any more progress or testing with this?
Enjoy,
Shad
Old 03-25-2020 | 12:57 PM
Hey, if you're okay with just buying off the shelf, I already have this product offered here. etsy.com/shop/LegoDEI . It has 360 reception and hit LED's, and provides an output trigger for an external relay or sound board.
