M4A3 barrel elevation issue >
Old 09-20-2019 | 07:25 AM
Default M4A3 barrel elevation issue
Hi,
Two years ago (2017) i bought an Heng Long M4A3 sherman that i wanted to turn into an m4a3(76). Which i did with the Nick aguilar's 3d printed t23 turret and had no problem as long as it was just a few wires to strip and reconnect. But recently I moved in another town and wanted to turn the tank into a more powerful sherman and i thought about an early model M50 Isherman (or super sherman as you want), and i couldn't find the old stock heng long turret. So i ordered an upper hull with electronics (turret and all the wires) from heng-long-panzer.de.
When i put it on the lower hull everything worked find except for gun barrel elevation, so i checked with a voltmeter the bb gun/elevation 3 pin plug to see if any wires inside the turret was cut off or something but everything was fine. I did the same on the upper hull board that connect the 3 pin to the 8 pin plug and everything's fine to. So i checked the 8 pin cable and again no dead wires.
This is where it becomes too tricky for me so if anybody have an idea i'm open to any suggestions thanks.
Old 09-20-2019 | 08:22 AM
HL recently changed their gun barrel elevation so that it goes up and down at will and no longer has to cycle all the way through. If you got a newer HL turret and your original tank used the old system I don't think the two will work together.
Old 09-20-2019 | 10:11 PM
After reading the posts and gave it some time to think. I remember when I was working on my sherman pershing hybrid I ran into a similar issue. Like what Crius said HL recently upgraded their electronics and the two systems are not compatible. On my build I used the hull of the new system but the turret was an older unit. It's been awhile and I'm a little hazy but I remember I had to make a change to the wiring on the turret to adapt it to work with the one in the hull. Regrettably I don't recall what I changed or where I changed it but it was fairly easy from what I can recall and after the mod the system worked like a charm. Hopefully someone else can chime in here with something more substantial.
Old 09-21-2019 | 01:40 AM
Actually the hull i bought has a turret with with the cycle up and down just like the first one but thanks for replying.
Old 09-21-2019 | 01:42 AM
Don't worry it's already a big step forward for me to know that it can be done because i was a little bit worried about it so thanks a lot.
