how to set up a tetanus qx7 for a tank
Hi, is there anyone out there that can step by step guide me setting up a tv tank using the teranis qx7 transmitter. I would like to be able to control, both tracks, turret turn, sound card for engine noise, main gun, and mg, also control a smoke maker. Thanks.
What brand name tank?
What Tank electronics board are you using?
Taigen, Heng Long, Clark, Tamiya, El Mod, BARC, Open Panzer, IBU, ASP.....???
I think more info from you is needed...
Enjoy,
Shad
Enjoy,
Shad
Im not 100% positive, but I think you will still need some kind of control board to manage the turret functions and trigger the sound card.
What size is the Tank? 1/16, 1/6...?
Shad
Shad
You can use a Benedini with no tank board. I doubt you will find a guide on how to setup all these things in one place. Did you buy the QX7 manual with your transmitter? The manual is pretty good. The only things that are pre-set on the Qx7 when you get it are the two sticks. The other buttons and dials need to configured in the radio in order to use them.
I am with the phone and I cannot paste a link but go to www.radindustries.wordpress.com and take a look at the reviews section. Read the benedini mini review and benedini board's tutorial.
Shad, the benedini is a standalone board, all is explained there, much more powerfull than most of people thinks. Problem is most dont know how to use it, hence I wrote that.
Hope it helps.
Hope it helps.
Shorty54 (02-07-2020)
