Tamiya Abrams steering problem.
I am running my Abrams with a Finespec24G with channels 1 and 4 swapped using the programming features built into the transmitter so all tank movement is on joystick 1. The tanks goes forward and back and turns right but will not turn left. I had previously used this transmitter and receiver on the Tamiya Pershing. I found I had to "write" the default button options on the A tank program, but I do not think this is the problem. I don't know if the is a electrical or transmitter problem or a mechanical one (I had no movement at all until I found there was a missing pin in one of holes of thegearbox shaft with two holes in the gear box and put the missing pin in, there are now three pins in the gear box shafts holes which appears correct.). Any suggestions as to cause/fix of the problem would be appreciated.
Thank You in advance.
BTY: The Pershing is running great using a Futaba T4YF with the joystick mod and function buttons I added (gun, mg, lights, clutch) following instructions on this forum (I do not remember the post, but thank whoever posted the instructions.)
I have a Tamiya Abrams with some steering problems but mine were specifically tied to gearbox issues. The steering drive in my tank at first wouldn't turn either way until I took it all apart and found broken gears for the stock setup. I added DKLM steel gears and now I steer fine but it clicks when I turn. Can't wait to open that up! On a side note, I have a Tamiya Sheridan using the Finespec radio and it runs great except my function buttons do not work at a all.... Still learning on that one....
My Abrams appears to have an an extra gear. I will check the gearbox to see if I have the right one in, but first I will switch channels back to 1 2 3 4. Currently I am running 4 1 2 3. To get a tank to utilize the buttons it has to a later model, the Pershing will not run on the 24G but I do not know if the Sheridan will, ask on the forum. For the Abrams I had go to tank A on the screen to see the function of each button and the scroll down and hit write. The buttons then worked.
Thank You for your reply
