H&L, Torro/Taigen Parts for Tamiya
I bought a second hand Tamiya Panther and would like to make some changes including Taigen Panther F turret/upper hull, dual current driving gearbox from H&L and some other bits like track tensioner and a smoke pump..
I am new into RC tanks and would like to know if those parts would fit on my Tamiya.
You can basically make any company's parts fit on any other company's tanks if you have the skill and the patience. The main thing to check for you would probably be the size of the hole that the turrets sits on, you might have to remove part of the upper Hull from the Toro tank and graft it onto the Tamiya upper, but it can be done. Like I said, as long as you have the skill and the patience. If you run into problems or have questions, come here because there are guys here that have done everything you can imagine with Tamiya tanks. And please post lots of photos, I'll be very interested to see how this comes out.
I don't believe the stock Tamiya electronics for the Panther will work with the Heng Long dual current gearbox. The stock Tamiya gearboxes aren't bad. There is also no smoker port on the Tamiya electronics as Tamiya doesn't use them. As far as smokers go a lot of us don't use them. There really aren't many real life tanks that actually "smoke" when running unless the tank has big issues. If you are firm in modifying your Tamiya to have those items, you will need different electronics. Typically the Tamiya electronics are meant to run a certain way and not great for making changes that aren't Tamiya parts.
Yes, I am aware that tamiya card wont work and thinking of DK Tank as it costs less and I can get one from Russia. I really like the sound of Tamiya card and may give up the gearbox to keep the Tamiya electronics.
I Built the Panther 2 a few years ago with the 88mm gun it was a paper panzer .
My Panther II Build
Jimmy
My Panther II Build
Jimmy
That looks great!!!. I have the parts to do one. Just waiting for Kenny Kong to re-release the his Tiger II travel tracks.
hetzer (08-04-2021)
https://etoarmor.com/?product=s03-et...y-transmission
I decided to utilize by Resin Printer which can print all the fine details. 88mm gun mantlet was the test print and came out quiet well imho.
In order to design the interior mechanical parts I am looking for cad drawing or dimensions of turret ring gear.
Can anyone help?
Gun Mantlet printed with Anycubic Aqua Resin
1/16 Turret
Can anyone help?
1/16 Turret
I like what you're doing here. It looks pretty good. Just out of curiosity, why don't you just get an actual turret ring? They only cost a couple bucks, is there a problem with availability? I think you said you're in Russia, Sevoblast may be able to help you or you might contact Forgebear in the UK. I'm pretty sure he ships to Russia and like I said, a turret ring is only about three or four dollars. Not sure how many rubles that is. Bwahahaha
Again, great job, I'll be watching with interest. And in case you haven't seen it, Rich Johnson did a pretty thorough review of the DK Electronics. I think you mentioned that you might use those. Hope that helps.
Also, I'm not entirely sure a resin printed turret ring would hold up. That resin can be rather brittle so I'm worried about teeth breaking off. You might be better off to just get an actual turret ring and use that. I'm pretty sure those are made from ABS plastic, but as usual, I could be wrong.
Yes, saw this before and trying to decide between eto and Henglong l65 transmission.
I made a phone call about DK board and informed that the new boards will be ready around December. I am sure Christmas will be a good excuse to buy some tank parts including the DK Tank Board.
hetzer (10-27-2021)
Can anyone help?
1/16 Turret
Can anyone help?
1/16 Turret
First print out.
There are some issues with the mesh but it came better than I expected. Gun mantlet cover was very thin and broken during cleaning process. I will work on the internal mechanics design and some improvements.
Somehow Schmalturm turret reminds me imperial hardware from starwars and It looks really cool.
Pnzjgr (11-06-2021)
I have realized that the gearbox shaft connected to left sprocket is bent from the e-clip cut. I tried to fix it with hand tools but it still wobbles. I could not find any spares for the Tamiya gearbox and thinking of replacement from Taigen. Before ordering from Aliexpress and waiting 3 weeks for arrival I would like to ask if it would be easy to fit taigen gearboxes to Tamiya Panther Hull?
