Self Centering
Old 12-08-2021 | 08:28 AM
Default Self Centering
I'm new to hobby and mostly interested in 1/10 scale, scratch built vehicles.
I bought a Radiomaster tx16S transmitter but need to convert the left stick (throttle) to be self centering. Can anyone point me in right direction. ?
Old 12-08-2021 | 09:06 AM
Check this
If your TX16s doesn't have the adjustment access "holes" in the front plates of the gimbals, then you need to fine-tune for tension from inside. I did not remove the tension bar like the guy on YT, releasing tension using the screws was enough to take away the rachet feel in my case.
Guardians Bane (02-04-2025)
Old 12-08-2021 | 05:47 PM
Awenzel1979's Avatar
Bob with Hobby Concepts sells the part needed and has a link to his how to video. Definitely recommend checking out his channel.
https://hobbyconcepts.net/products/f...-centering-kit
Old 12-08-2021 | 05:51 PM
You don't need any extra parts to center the stick in a TX16s. This is not Flysky.
Old 12-09-2021 | 07:14 AM
Thanks guys, exactly what I needed. Was a lot easier than I thought it would be as well.
Awenzel1979 (12-09-2021)
Old 02-04-2025 | 04:46 PM
[QUOTE=sclui;12705938]
Thanks for this link! I'm getting one of these for ground vehicles. I wanted self centering throttle and the vid is perfect! Again, thanks! (From the future? Lol I see this is a bit old.)
