Heng long T-90 question/ idea
Hello
just got a Heng Long T-90 which I am repainting and doing a bit of detail work. Very nice tank as compared to the original Tiger I got way back when( prior to a Tamiya Tiger). I noticed that there are two real big gaps under the hull where the turret gear traverse ring is visible. I figure a lot of dirt/dust will get up in there thrown as the track moves. Has anyone done a mod to seal off this area? Picture included. Maybe this isn’t a real issue, just me worrying.
thanks
Dave
thanks
Dave
I hadn't noticed this on my T-72, but all of my tanks get dirt in them. I just blow them out occasionally as none of them are completely sealed up. I don't run them in water so that isn't a concern of mine.
regsbyg (04-03-2022)
Hello
thanks
Dave
thanks
Dave
But if the gap bothers you by all means cover it. It’s your tank after all and you have to be comfortable with how it is set up.
I open up mine every few hours for some reason and when I do I blow any grass or dirt out. It's never enough to worry about, not even close, maybe one blade of grass and a little dust in the corners. I have other tanks that seem more sealed that collect more debris.
regsbyg (04-04-2022)
The more holes, the less dirt, it just does not linger in the case ....
He made a sealed hull, a lot of effort and money, and as a result ... water got through the tower and made trouble, because. remained at the bottom of the tank .......
