Heng long t90 v7.0 RC tank
I have a Heng long t90 version 7.0 RC tank. 3938.
Does anyone else have one of these ?
The tx has a "rear lights" on and off function with a sound to suggest that the function works, but no rear lights seen ?
Where are the rear lights, marker lights and brake lights ??
The front lights turn on and off ok.
Also, laser ranging function ?? No Lazer warning on box ?
Is there a micro WiFi camera available for this model ?
Last question, I assume the turret and top of tank hull come of the base hull by removing the 4 corner screws ???
Thanks in advance....
![](/forum/images/badges/premium_member.png)
I have the tank, but I believe mine has the 6.0 electronics. These transmitters are used for a lot of different tanks, some with rear lights and some without, but they all use the same TX so if your tank has rear lights they will work, but if it doesn't have rear lights it will still have the switch. Have you ever had the tank opened up? I would suggest checking the MFU, just to see if anything is plugged into the light port.
As for the fpv camera, take a look at this
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
Hi crius,
wow, that was quick !
Tank under gaurantee so reluctant to "go in for a look-see"...
UK importer ( j Perkins ? ) Extremely slow with any meaningfull feedback, difficulty In contacting manufacturer to ask them directly...
Will have a look-see about camera you mentioned...
Thanks...
Anyone recommend video about gaining access to model internals ?
Thanks...
You being UK based would do yourself a favour avoiding Perkins, I bought my first R/C Tank from them,As far as they were concerned that was it transaction complete goodbye,
If you want good service go to www.rctank.de or www.forgebeartanks.com both of these dealers although they are Taigen vendors they will look after you.
