pershing having problem will not move
need help pershing will not move[:@] all other funtions working do not know what could be problem[
] any body have same problem using fotaba t4yf
Given the radio,it's a Tamiya. This problem fools a lot of people, it's in 'rev' mode, you need to take it out of rev mode by pulling the left stick backwards as well as its corresponding trimmer , then it will drive around.It tells you about this in the instructions somewhere.
Neville
Neville
Banned
My Feedback: (-1)
Nev mentioned "left" stick assuming you use left stick for "throttle". just do the trick on the "throttle" stick wether it is right or left.
good luck. thankst,om
