 hl pershing to m4 sherman mod >
Old 03-18-2006 | 12:20 PM
CreepingdeathRC's Avatar
Default hl pershing to m4 sherman mod
anyone ever think of modding and cutting a henlong pershing into a an m4 sherman with a little bit of fiberglass its possible. It would be fun cheap alternative to a Tamiya sherman. the modded sherman would kinda look like the "easy eight" variant.
Old 03-18-2006 | 05:51 PM
Harquebus's Avatar
Default RE: hl pershing to m4 sherman mod
That would take a lot of work to make it even remotely similar to the Sherman. The hull shape, the turret shape and the running gear is totally different and you'd be better off converting it to an M-46, M-47, M-48 or M-60 Patton variant than the Sherman.
After all, you'd want it to look good, right?
-Harq
Anyway, I imagine before too long there will be a Heng Long 1/16 Sherman and if I were them and just to make it slightly different (so it won't appear as a direct copy), I'd make it with the standard 75mm instead of the 105mm howitzer version [:'(] which isn't really a tank but mobile artillery.
