Need Some Help!
Old 03-23-2006 | 08:14 AM
Default Need Some Help!
HI EVERYONE, COULD SOMEONE PLEASE TELL ME WHERE THE RED WIRE FOR THE BB FIRING MAIN GUN ON THE HL TIGER GOES???
I DIDN'T REALISE THAT I SNAPPED IT OFF WHILST RE-ASSEMBLING THE TIGER, JUST NOTICED IT LAST NIGHT...
BEERGUTT ( 0 )
Old 03-23-2006 | 08:32 AM
Default RE: Need Some Help!
No need to yell (ALL CPS!!!) If you chec out my thred on [aint Rumnhammer has where all the wires go, but to make it easier on you: the red wire coming off the main gun motor goes through the harness and to the little square that has three wires attached, under the upper hull. If that doesn't explain it please be more specific where the wire is loose or take a pic so we can help you better.
Old 03-23-2006 | 08:59 AM
THATS THE ONE! IT HAS COME OFF OF THE MOTOR END, CAN SOMEONE SHOW ME WHERE TO RE-SOLDER IT BACK ON???
(SORRY ABOUT CAP LOCKS BUT THIS IS WHAT I'VE BEEN USED TO SINCE THE BBC COMPUTER DAYS!
BEERGUTT ( 0 )
Old 03-23-2006 | 01:25 PM
LOUD NOISES!!
Old 03-24-2006 | 11:22 AM
CHEERS FOR HELPING, I'VE NOW FOUND OUT WHERE THEY BOTH GO...
BEERGUTT ( 0 ) (WHOOPS, CAPS ON AGAIN)
Old 03-28-2006 | 05:56 AM
Hi,
I have a Heng Long Tiger (just arrived). The problem is that it does not work - any suggestions?
I have power to the R/C controller (red light on) and power to the tank (headlights flashing). As a precaution I have replaced both sets of batteries.
Pressing the engine start (extreme L/H button on the controller) has no affect - any suggestions on where to go from here?
Will
Old 03-28-2006 | 06:05 AM
How long did you charge the battery?
Do you have any way to test the battery?
Are you using the battery it came with?
Check to make sure that the crystals match, in the transmitter, and in the battery compartment.
Old 03-28-2006 | 06:18 AM
The battery it came with was charged for 11 hours and produced the same results (flashing lights but no start up).
The new battery was charged for 4 (the amount of time the model shop recommended).
Crystals are both 03 rated.
Old 03-28-2006 | 07:30 AM
I would think you have 2 options. Contact the co. you bought it from and see if they will exchange it, or you can take it apart and see if there is anything loose on the inisde. I would try to avoid the later as it may void the warranty (depending on where you bought it from.
