Need some help
Old 03-24-2006 | 04:08 AM
Default Need some help
Hey there
I have a problem,its my remote controll for my HL Tiger (its 40mh on the left side of the pic) and the one at the right is a 27mh.Well if you move the stick to the front those small connectors should go right above and slightly touch the microchips,well my connectors are 2mm to far above the chips.So in my endless stupidity i bought the one on the right (27mh) since my tiger is a standard one (without sound or smoke) well i found out my Tiger needs a 40mh one wich means,I'm back where i started.So right now I'm thinking of taking the 40mh chip out of the remote and put it into the 27mh one,what do you guys think? is that a good idea?and the other problem with my 40mh remote is,if you let go of the stick the stick is supposed to go right back into the middle,well on my remote if you move the stick down its not going back to the middle.Or should i just remove bouth controller stick`s and replace them with the one from the 27mh remote???????So can you help me????
