Adjustment of Tamiya DMD Control Unit
I am trying to complete the adjustment of the DMD control unit on my Tamiya Sherman, it doesn't seem to be happening for me. I am following the steps but when I finish and try to initiate the guns firing noises, nothing happens. Though, I was able to activate one of the machine guns firing sound but that has since disappeared. I am doing all of this prior to installing the unit inside the tank and hooking up the guns, turret, lights etc.... I am just taking it step by step as in the manual. The "alternate flashing..." lights the manual says to look for on the DMD unit flash way to fast for me to notice any change in pattern so I don't know if I am accomplishing anything when I move the transmitter sticks as directed in the manual. Any advice would be appreciated. Thanks for your time, I am lost here.
Jeremy
Jeremy
Banned
My Feedback: (-1)
Jeremy,
do not worry, it sounded no big problem.
first of all, what radio do you have?
if futaba, adjust the trim from 100% little by little until 90%, fire the guns every time you move the trim until you find the perfect spot for firing.
good luck
tom
good luck
tom
Tom,
I do have a Futaba. When you say adjust the trims from 100%, do you mean move the trim (the ones directly by the stick or the ones below the sticks) all the way up (towards the top of the radio) then slowly move them down? Thanks for your help, it is much appreciated!!
Jeremy
Jeremy
