 Would these batteries work? >
Old 04-21-2006 | 03:50 PM
dacostasr's Avatar
Default Would these batteries work?
I saw these at Towerhobbies....will they work ok?
Team Orion 6-Cell 3000mAh Super Duty Plus NiMH
http://www2.towerhobbies.com/cgi-bin...&I=LXCUH3&P=ML
Old 04-21-2006 | 04:25 PM
Default RE: Would these batteries work?
These are absolutely perfect for my t34!! Currently my full option t34 (Tamiya Pershing Innards), is powered by two subC-cell battery packs, 1200 mah each, giving me a run time of 40minutes. These will triple or more my run time. Sub-C battery packs, which were first used on the micro RS4 electric cars, are perfect for the WSN and Bandai projects or even the Tamiya Pershing, which is super tight if built by the book. Thanks for the info!!
Old 04-21-2006 | 07:32 PM
greetings dacostasr as sownare has said the pershing lower hull is a very tight fit even if you go by instructions for arrangement of components and battery placement so battery size is very important i do not know exactly what my battery size is in mah but the measurement is 1"x 1 7/8"x5 1/8" i'am guessing at maybe 3800? i have run the pershing for about 50 min. and not run battery completely down so this is food for thought or maybe if you know somebody that has different size batteries and try them to see what fits the bestdan
