Help with HL tank please
Old 06-10-2006 | 05:19 AM
Default Help with HL tank please
Hello i am new here. I have just got a HL Tank 1/24 T-90.
When i tried it it wouldn't run forward, When i press forward only the wheels on the right side(seen from front) move and the tank just spins around in circles to the right.
It runs perfect backward and can turn without problems. But when i drive forward it only goes around in circles.
I opened it up and went over it checking everything but i can't seem to find out what is wrong.
Can anyone help me or does anyone have any ideas on what is causing this ?
Can it be the controller/sender ?
Any help here would be nice
Thanks[]
Old 06-10-2006 | 05:31 AM
Harquebus's Avatar
Default RE: Help with HL tank please
Try opening the controller next. Check for loose wires and where the buttons make contact with the circuit board.
Others will advise as well.
-Harq
Old 06-10-2006 | 05:45 AM
Harquebus's Avatar
Also, try this site: http://groups.yahoo.com/group/MaruiTankGroup/
They discuss Marui as well as Heng Long tanks. Lots of info available there. You will probably have to join Yahoo to gain access.
-Harquebus
Old 06-10-2006 | 09:45 AM
icecreamslick's Avatar
My Feedback: (9)
I suggest that you contact the seller immediately and get a refund or an exchange. [] Those tanks have a reputation for low quality and if you monkey around with anything in there, you may have no choice but to try to fix it yourself.
Jason
Old 06-10-2006 | 10:43 AM
Banned
My Feedback: (-1)
Jason, good luck on your purchase.
