Tamiya Leopard Grease
Old 07-11-2006 | 01:58 PM
From: stourport on severnstourport on severn, UNITED KINGDOM
Default Tamiya Leopard Grease
What type of grease do I need to use on the nylon gears? Also what type of glue is best for the lower hull and suspension bits that have to be glued on?
Thanks...
Old 07-11-2006 | 02:23 PM
heavyaslead's Avatar
Default RE: Tamiya Leopard Grease
White Lithium grease does well for the nylon gears, available at most hardware stores.
I use CA glue for the parts that will never be removed. It also bonds plastic to metal fairly well too!
