HL Pershing with a problem
FL
My Pershing will not fire the BB's It makes the noise and I've got the kit BB's and the walmart BB's.I jammed an antenne tube down the back and got it to fire one BB. Other than that it just makes the noise. What to work on? does it need some type of lube? When is the conversions stuff to make it like a Tamiya battle system coming out?
You'll have to open it up and investigate. Has it fired fine before? It's probable that the breech is busted and will need replacing.
