First sherman run video
Old 10-19-2006 | 06:57 PM
shenlonco's Avatar
Default First sherman run video
Took it out for the first run ever..It's awesome!!
[link=http://www.youtube.com/watch?v=fO8_Jbbs72o]sherman first run[/link]
shen
Old 10-19-2006 | 07:22 PM
Default RE: First sherman run video
the sherman cannon looks pretty cool (the light)
Old 10-19-2006 | 07:27 PM
I hate you! Very Very NICE!
Old 10-19-2006 | 07:36 PM
briz's Avatar
I never could get my "headlights" to ever work......wonder what I did wrong.
Old 10-19-2006 | 09:08 PM
shenlonco's Avatar
your lights should go on when you have the trim slid all the way to the right then you push the stick all the way to the right ...the one that rotates the turret.
Shen
Old 10-19-2006 | 09:11 PM
briz's Avatar
I know....just does not work[]
Old 10-20-2006 | 01:33 AM
Briz:
You may want to re-set your DMD, and make sure your trims are centered when you do so. Setting off the guns and turning on the lights is done the same way (unless you rigged gun switches)
You have to slide the trim first, then almost jerk the stick to full throw. Too slow and the DMD doesn't get the right signal, and you get traverse.
There is a way to manually check the power, and you can use your unused 4.8 Rx battery. Use two scraps of wire and jump the Sherman light-harness leads to the battery. No, polarity does not matter, these aren't LEDs. The lights should light, though dimly. If not, you may have a crushed or blown bulb or a severed wiring line. I busted one bulb, and because they are all in series, nothing would light until I shorted across the busted bulb.
And before ya order a Pershing harnes... they aint compatible. Already tried it. I'm not even sure the bulbs are cross-compatible.
End of Sherman lighting lesson 101.
