panther idler wheel
panther idler wheel
hey, i had my first track problem for my panther... well the idler wheel came off. there is a screw inside the idler wheel and threads where the wheel attatches to the tank. so how do i screw the screw in? there isn't any access to the screw head that i know of.
RE: panther idler wheel
Hi Kuhndog, if it is the front drive sprocket that has came off you have to lever off the inner circle of the sprocket with a flat head screwdriver if it is the rear idler you have to lever both parts of the idler apart again with a flat head screwdriver just be careful so as not to break anything[&o] hope this helps
Cheers Ian
Cheers Ian
Since the running gear is Tiger I running gear, I am told that the screw is hidden by a "hub cap" that is glued over the screw. This has to be pried off. Care should be taken so as not to ruin this piece.
Since I am not a Tiger owner, I would await confirmation and details on the best method for removal.
EDIT: and I can see you just got that confirmation. I need to respond faster I reckon...
-Harq
-Harq
