Tiger won't respond
Tiger won't respond
Hi. I have a HL Tiger that won't respond to the remote. The sound doesn't activate, the lights don't come on and it won't respond to the remote. does anyone have an Idea to how this might be solved?
QC, CANADA
RE: Tiger won't respond
hi ,
when you swich it on , does the light on the tank blink(flash) ?
did you try the controller near the tank`s antenna , 1/2 inch?
do you have an antenna on the tank-check also antenna wire from the tank.
did you play outside with it or abuse the motors pushing something?
QC, CANADA
if the lights does not blink when switched "on" and the battery is well charged(until it get warm ,not too hot).
i think your circuit board is fryed..[:@]
run other test ,inspect electrical wires inside(unweld)
check some other repplies in here later.
contact nova hobby(canada) on ebay for a replacement circuit board(15$) or matotoys $17.00
have installed a new heatsink and a cooling fan in mine ,no problem since.
