what motor?
what motor?
Hi Guys, does anyone know what motor this is? 280? 300? Dimensions: 58mm overall length including the shaft and pinnion, 27mm can width, 45mm overall can length. It's one from the pair that power my 1:12 Abram's M1A2 Hailaing and seems to be of very low quality! I had just finished testing my Tri Pact Speed Controller when this motor began to smoke like mad! I switched off and when it cooled down it still worked, but way down on power causing the Tank to pull to the left. I replaced it and all is well again but now I've only got one spare Hailaing motor left! Also if I can get decent motor replacements, how could the 11 tooth pinion be fitted to the shaft? Are there 11 tooth pinions available with grub screws like tamiya? Thanks in advance!
