stuart 1/6 sound conversion
Somebody already tried to use a Tamiya DMD and MF sound unit in a 1/6 stuart?? Could i plug the tamiya electronics boards directly to the 12volt batterie and use the stoch stuart motors (drive and turret)?
Thanks for your help
AZ
RE: stuart 1/6 sound conversion
I would NOt plug a 12v battery into DMD....although I have seen it done on the UK tank forum(on a Stuart no less).
I would get a Pro-Max 7.2v,6-cell 3800mAh/Ni-MH battery......they are AWSOME!!!!!!You will not risk frying DMD and battery has enough power to drive the Stuart......my .02cents
