electronic problem whits a RC TIGER 1
hello,i've just by to my son a rcTIGER 1,his cousin make a 180 degrees yo the turette !!
now the turette doesn't turn with the comand,i tried to use other alimentation (the shooting gun)then the motor of the turette work,the comand of the remote work to,noise of motor when i comand to turn the turette,so i'm bloked
did some One can help me pleaseeeeeeeeeeee
thank's for attention
byby Ricci
byby Ricci
Are you saying that the turret is stuck? in the 180 degree positon? if so, it may have siezed in some way at that point. can you turn it by hand? this will not damage the tank. You may need to remove th turret and check.
The turret doesn't turn 180, It turns 320 degrees or 160 per side. If the Tiger's barrel is in between the two exhausts then you have to open up the tank and inspect for damage and unjam it. Often times a new tank will jam a little as the wiring gets in the way, this usually sorts itself out by turning completely in the other direction.
I did some work on a Tiger once, buttoned everything back up and the turret wouldn't turn either. However, that part of the board fried, everything else is functional. You do have a spare board don't you?
