Whats with the Metal Tracks?
IL
I put the metal Tracks on my T 34/85 last night and they seemed to me to be real tight. I know they need to stay on the road wheels and idelers since there is no tensioners on the Soviet tank. I took them off and put the plastic ones back on, are they supose to be that tight? I am afraid that the resistance will burn the motors out from excessive load.These are the Tracks from MATO. I even calibered the Plastic set and the metal set, only +/- 1mm difference. The tolorance is fine so what gives? Is there a metal gearbox set out there for the T-34 that I might have missed? Thanks guys Anthony.
1 Post
RE: Whats with the Metal Tracks?
the T34 does have a tensioner in the front of the tank..the trick is you need to take the tank apart and you will notice that the
front wheel mount has teeth and a screw from the inside that you can loosen or tighten the tracks.. I discovered it on mine back in November..
I hope this helps.
Mark
I hope this helps.
Mark
IL
My tank is apart right now REPAINTING, Ok I seen that yesterday but didn't put it together that it could be a screw you can set. Thanks man!!!!
