Suspension arm problem
Old 03-03-2007 | 12:03 AM
Default Suspension arm problem
Hi guys just seen on my panther the suspension arm has totally came out pretty much.
Its came out of its little hole and i can see a big spring.
Whats happened?
Any help greatly appreciated.
Old 03-03-2007 | 11:46 PM
Default RE: Suspension arm problem
Any help at all guys.[]
Or could u give me some links to other threads that can answer my problem cause i dont have a clue when it comes to suspension arms.[]
Old 03-04-2007 | 01:35 AM
Sorry, I don't own a panther. I can't help much except to say look at it thoroughly from all angles, find out why it broke, and how it broke. You kind of need to be a failure analyst with these tanks. Once you conclude the reasons for it's failure, think of what you can do to fix the problem. But don't just fix the broken one... find a way to prevent further failures on the remaining suspension parts.
Old 03-04-2007 | 06:34 AM
Killhammer's Avatar
The axle that holds the swing arm has broke is what it sounds like. This has happened to alot of the axles on my Tiger. I,ll Try to find some threads, here is a thread I up on when my first axle brike.
http://www.rcuniverse.com/forum/m_46...tm.htm#4634975
Old 03-06-2007 | 05:26 AM
Yeh thanks mate thats probably what happened.
