tips on spray painting.
Old 03-09-2007 | 11:49 PM
Default tips on spray painting.
Hi guys i just thought i would give my bulldog a spray is there any good techniques on how to spray and suggestions on colors would be good also.
Kind regards pantiger man.
Old 03-10-2007 | 07:56 AM
swathdiver's Avatar
Default RE: tips on spray painting.
Stay away from pinks and yellows, stick with earth tones. People will look at you funny if you drive around in a pink tank.
Old 03-10-2007 | 09:31 AM
Richard L.'s Avatar
My Feedback: (24)
ORIGINAL: pantiger man
If you plan to spray from a spray can, slightly warm it up in luke warm water, shake it vigorously for one minute, then spray 10-12 inches away from the surface. Start/stop spraying off the tank. In other words, you do not depress the spray button while pointing the nozzle directly at the tank. If you plan to spray from an airbrush, thin the paint accordingly and spray with adequate air pressure. In both cases, wear a respirator because paint particles will stick to your lungs, and it's difficult to get them out.
Old 03-10-2007 | 09:52 AM
ORIGINAL: Richard L.
Good advice man
Old 03-10-2007 | 10:36 AM
swathdiver's Avatar
So that's why I've been sneezing up red oxide primer!
Old 03-10-2007 | 12:37 PM
Richard L.'s Avatar
My Feedback: (24)
You know how sometimes you hold a part in your hand, spray it, and the overspray ends up on your skin? Well, at least you can get to the overspray to clean it off. You cannot get inside of your lungs without taking extreme measures.
Old 03-10-2007 | 05:12 PM
Banned
i found one of those long handle loo brushes works well
Old 03-11-2007 | 02:42 AM
Thanks for the help guys much appreciated.
Old 03-11-2007 | 06:51 PM
Harquebus's Avatar
Suggestions on color? Post-war US tanks were usually painted in an olive drab that was darker than that used in WWII. I've even seen a semi-gloss greenish brown used on tanks during the early interwar-period (kind of like the brown used on UPS trucks).
Paint schemes:
http://www.rcuniverse.com/forum/m_5223016/tm.htm
Here's a fine repaint in tricolor NATO camo but some of the picture links are broken: http://www.rcuniverse.com/forum/m_4521791/tm.htm
